Help!~~~
I purchased a piece of WinTV PVR PCI.
When capture and playing back MPEG1, it's no problem.
However, when I capture MPEG2 and play back the captured file using the
winTV2000 app, it only shows black screen with normal sound. Why?
I'm using win2000 server and have installed directx 8.
My VGA card is a S3 Savage 3D.
My PC has 256Mb RAM and is a PIII 500MHz.
Also, the video editing s/w shows black screen with sound when loading both MPEG1 or MPEG2. Anyone knows what the problem is?
Thanks!
Dose it play back with in the Windows Media Player?
Any solution? -
Did you install the MPEG2 decode software?.
Go my web site under download you find ever thing you need there
http://www.shspvr.com
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 08:43 -
better unit than my old wintv pvr usb2
By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 09:52 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 19:40 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 06:54 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 10:39
