How do I separate the audio from an MPEG-2 clip in "MPEG Video Wizard DVD" (editing program), import it to Audacity, filter out the noise (pops), then export it back and re-sync it to its video? I know it's a lot, but thanks!
You can demux using Rejig or DGIndex. You may have to convert the audio to WAV using Besweet before you can work with it in Audacity (not sure if audacity reads mpeg-1 layer2 audio). Once you have finished your cleanup, export as wav, convert to mpeg-1 layer with Besweet again, then mux with muxman or similar.
Read my blog here.
Not sure about the demuxing with MVW, but Audacity only accepts a few audio file types. For MPEG, it would be WAV format. For that, I use VirtualDub Mod and extract to WAV with full audio processing and use that with Audacity.
Once I finish the audio filtering with Audacity, I output as WAV again and use ffmpegGUI to convert to AC3, then use a authoring program to combine the audio back with the video if my final output is DVD. Another option for AC3 conversion if Aften.
Many other ways, though.
A few other points:
I suggest the latest beta of Audacity (1.3x). This has some real improvements in the noise filters over 1.2.
Also, to keep sync, do not delete sections. Use the "silence" button to remove pops, etc if you're doing it manually. (Or try the "repair" effect).
Audio Hiss Problem--I tried audacity
By bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 08:55 -
Just getting started on audio--removing a squeal with Audacity
By solarblast in forum AudioReplies: 13Last Post: 14th Mar 2011, 11:17 -
Why does Audacity always save audio files differently?
By sldvd in forum AudioReplies: 15Last Post: 22nd Nov 2010, 14:17 -
Cleaning up a concatenated MPEG-2
By thinker3932 in forum Video ConversionReplies: 22Last Post: 25th Aug 2008, 20:37 -
How to set streaming audio input to Audacity?
By edDV in forum MacReplies: 2Last Post: 25th Aug 2008, 13:19
