Hi I'm using a software called SUPER and I was wondering if there is a way to change the font & font size?
	Of what ? The interface - no. SUPER tries to fit everything it can into the one interface screen, which means you have lots going on, small fonts, and lots of clutter. If you want something easier to read, try a different tool. Other tools that convert many formats to many formats include MediaCoder and Xvid4PSP (which does a far better job than SUPER in most cases) Read my blog here.
	For the subtitles not the interface. I don't think the tools you mentioned can convert from h264 to avi
	Both can convert h264 to AVI quite easily (and go in the other direction).
 I haven't played with SUPER in a quite a while because Xvid4PSP is far superior for the things I do. Xvid4PSP also does subs using TexTSub in avisynth. You can edit the script to modify the subs in any way the textsub allows.Read my blog here.
	Besides which - as far as I'm aware, SUPER doesn't handle subtitles. It'll ignore subtitle streams, basically.
 An exception could be subs burned into the video... but in that case, you wouldn't be able to change their font or color, anyway. If cameras add ten pounds, why would people want to eat them? If cameras add ten pounds, why would people want to eat them?
  SUPER conversion question...By mjl1297 in forum Video ConversionReplies: 9Last Post: 7th May 2011, 15:17
  Eumig 607D Super 8 projector questionBy afoggynotion in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2011, 16:13
  Question about 'Super' converting RMVB -> iPhone (MP4)By blackhole001 in forum Video ConversionReplies: 8Last Post: 4th Jan 2010, 01:46
  Question about SUPERBy AlecWest in forum Video ConversionReplies: 0Last Post: 17th Apr 2008, 20:24
  SUPER DVD CREATOR 9.25.0 QuestionBy Jboogie70 in forum Authoring (DVD)Replies: 2Last Post: 24th Aug 2007, 06:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
