I recently purchased a HD Capture Card (Black Magic's Intensity Pro) for my Mac Pro. It captures at 720p and 1080i, but sadly doesn't have the ability to capture 480p. I want to capture some footage from my Wii, which you may already know is only capable of producing a 480p signal. This leads me to my question -- Is there a cheap way of upscaling the 480p Wii output to a 720p output so I can capture it with my capture card? I personally don't want to spend $1500 for a home theater upscaler since my only plan is to capture Wii footage.
Thanks in advance
Ryan
Are you sure it won't capture 720x480p?Originally Posted by OryanRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm pretty sure :'(Originally Posted by edDV
HD: 1080i/59.94, 1080i/50, 720p/59.94, 720p/50,
SD: NTSC and PAL. -
Have you tried? They aren't very specific. Calls for a test.
Yeah, I've tried. It doesn't recognize the input at 480p. When I change the wii's settings to the default 480i and use the regular component cables, I am able to record with the NTSC preset (720x480). I'm trying to record the 480p signal since it is much crisper.Originally Posted by edDV
Few questions: Upscale SD to HD?
By nic3 in forum Video ConversionReplies: 5Last Post: 9th Jan 2011, 10:32 -
vob to mkv upscale?
By nasdravi in forum DVD RippingReplies: 2Last Post: 13th Jun 2009, 10:11 -
So Will it upscale your VHS tapes?
By dvd3500 in forum Latest Video NewsReplies: 20Last Post: 17th Jan 2009, 00:37 -
hdmi upscale through pc
By zinc in forum Software PlayingReplies: 3Last Post: 30th Aug 2008, 12:57 -
Playstation 3 - do they upscale non-BD DVDs?
By snadge in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Feb 2008, 20:35
