    Jun 2007
    Ireland
    hey,
    ive just made an iso file with FAVC to put on dvd,it went fine accept for the playback on the iso which would be the main thing ,the input is an 8gb 720p mkv 23.976fps,,,,,and output is a pal 25fps 720 x 576,wen i playback the iso file it seems jumpy like stoppin and playin real quick,audio and video are still in sync,mabye it has somthing to do with the fps,can som1 tell me if i have to change settings or somthin?or if i need to be using a different proramme,
    hope you can help,
    Eao.
  2. Member fatbloke88's Avatar
    May 2006
    try running your file through mkv2vob and loading the vob into favc,I get the same effect if I stream mkv and it seems to solve that.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    mkv allows for variable framerates etc, which can cause this type of problem.
    You can also try DVD Flick or ConvertXtoDVD for mkv files.
    I would also avoid format conversion if you can. Your player should be able to handle NTSC playback with the need to convert to PAL first.
    Read my blog here.
    Jun 2007
    Ireland
    hey guys just seen ur posts thanks for the replies, il try both and get back to yez,
    eao.
