I have laptop with HDMI output and I have TV set with DVI input and multiple audio inputs.
I would like watch movies from my laptop. I can bring the picture using DVI2HDMI cable but I can not bring the sound because there are not other outputs (audio) on the laptop.
Is there any way to get DVI and audio signal from HDMI ouput?
Thanks, Igor
Normally you would use the headphone output to feed analog stereo. Or a dock that feeds AC3 over SPDIF.
Otherwise you would need an AC3 receiver that splits off audio. This won't work well if any HDCP blocks are triggered.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
Question about DVI-D & DVI connections ?
By VEBouto in forum ComputerReplies: 2Last Post: 27th Oct 2010, 08:28 -
Computer DVI output to TV DVI input
By superdud1400 in forum DVB / IPTVReplies: 12Last Post: 13th Jul 2008, 09:44 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 06:49 -
HMDI Connector is a Poor Design
By Snakebyte1 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:46
