  1. Member edDV's Avatar
    On weekends I like to record tech streaming radio broadcasts (e.g. Leo Laporte on KFI) to Audacity and this works fine on my PC laptops (XP or Vista).
    I want to use my Mac as an alternate recorder.
    First I installed Flip4Mac WMV to get WMV streaming support into Qucktime and can hear the broadcast fine.
    Next I installed the Mac version of Audacity but can't connect to the stream for recording.
    Anyone know how? I had to struggle with Vista audio into Audacity and solved that, how do I do it on an Intel Mac?
    http://www.kiva.org/about
    Audacity works a bit differently under Mac OS than under XP/Vista. You'll need another app to enable capture. Audio Hijack is one.
    See http://audacity.sourceforge.net/help/faq?s=recording&i=streaming
    for additional info about this topic. As you can tell, it's one of the more popular questions.
    Good luck!
  3. Member edDV's Avatar
    Thanks for the tip.
