Hmm...well, my burner's a Optiarc AD-7173A (Sony) and I used both GQ (Rich JPN) and Philip DVD+R DL discs. Both of which has massive pauses. At first I thought it was my burn, but then the discs played perfectly with my RCN player. That's why it leads me to think it might be this player that doesn't actually support DL discs. To be sure, I did contact Philips and the reps told me it isn't supported. Go figures.Originally Posted by Tripper_
				Results 151 to 180 of 949
	Then I would try a Verbatim DL + disc and see if that makes any difference.
	GQ is total shit. There's your problem right there.
 Philips is shit with a ribbon on it.
	What do you mean by....Philips is shit with a *ribbon* on it?Originally Posted by Supreme2k
	Meaning not quite GQ level shit, but still pretty awful.
	Yes, the media your using is terrible. You probably need to update your drives firmware. Liggy and Dee do a great work with modified firmware.Originally Posted by PixelaseR
 http://liggydee.cdfreaks.com/page/en/Optiarc-AD-7170A/
	Acutally, I already did that. It's currently on the latest Liggy FirmwareOriginally Posted by Tripper_
	anyone have any idea why my 1_2 firmware is only showing 25 char for files/folders?
	Originally Posted by WickedDevilsYESOriginally Posted by Supreme2k
	LOL, there's a 2nd that can't get DVD+R DL to work right.
 Guess I ain't the only one
 But seriously, I think it has something to do with the software used.
 I've used Nero, ImgBurn, Alcohol, CloneCD AND CloneDVD. All of them gave me nasty pauses all over the 2nd half of the disc. It's totally annoying. Some of the discs even freezes like 3/4 of the way.
 Kinda hard to believe that this is a media problem.
	It must be serious if it brought out Mister 2 Posts per Year
 So, you've used several different programs, all with the same results, yet you don't think that it may be the media?! You've already admitted that you use crap media.Originally Posted by PixelaseR
 Try a Verbatim, then let us know if you have the same problem
	I am in the process of obtaining a Verbatim DVD+R DL. Kinda trying to find one at a more acceptable price rangeOriginally Posted by Supreme2k
 However, just so that you know, those disc works in my RCN DRC unit. That's why I didn't think it's the media.
	so what's the most recent firmware update? or which one should I use?
 I don't need anything too fancy, but I'd like to see more characters when browsing files off the USB, and I'd like those files to be arranged alphabetically! I use standard notation on episodes (SXXEXX), but it doesn't help if 1) you can't read the whole name, and 2) they're not in the correct order.
 It's a U.S./North American 5990. Just bought it.
 Thanks.
	I am using Verbatims. The same ones that the 360 reads. The DVDS I burnt play fine in that. In the 5990 it just sits loading forever. I use CloneDVDOriginally Posted by Supreme2k
 My dvd player is the Pioneer 111D
	OK figured it out. If I leave the dvd sit long enough the movie finally plays.. haha
	Hi folks,
 can this firmware http://rapidshare.com/files/151869008/DVP5990_37_vb6_v1_2_1_PAL_default.rar.html also be used for my 5990/12 (bought in Germany)?
 Thx in advance
 Alibaba7
 EDIT: is there a limitation besides FAT32 for an external hard drive?
	I really don't understand you...Originally Posted by Alibaba7
 It's so hard to read main index and find what you want?
 It's a BIG topic about 5990/12 version....
	Thanks for the firmware. Just loaded it on my 5990/37.
 Question:
 Is it possible to associate a jpg with a divx file,and get jpeg preview? (xtag)
 so that when looking through the list of divx, I see cover art?
 thanks
	* New "File Cutter", number of character in FileBrowser is limit now to length of "yellow" band.(More than 40 char.)
 not on mine? flashed and reflashed it with nothing getting better, is there something else you have to do besides upgrade the firmware? like a reset?
	Originally Posted by bschmitt77
 If your using usb you will only get around 23 characters.
	I really used the search function. There was no result because I searched for 5990/12 and not for 5990. Didn't look at the index because normally the search function is much better. Anyway. Thx for the hint.Originally Posted by vb6rocod
	Good news for russian guys!
 I made support for cyrillic in vFAT code for USB. Just stay tuned - I need some time to make description.
 dvp5990_37_vp6_1.2.1_cp1251_usb.zip
	The new file browser shows only four files at once. Is it how it supposed to be?
	Originally Posted by jimsmith
 READ THIS THREAD IT HAS ALREADY BEEN ANSWERED!
	Thank you so much for uppercase letters! It now so much more readable!Originally Posted by Tripper_
	lol, Nothing like a little shout out.Originally Posted by jimsmith
	Yeah, I hope you feel yourself relaxed now...Originally Posted by Tripper_
	Has nothing to do with being relaxed. You've been a member of this forum since 25 Aug 2003. You should know better. I added to my initial post so hopefully it will encourage to read first. This way we won't continue to rehash the same questions. ThanksOriginally Posted by jimsmith
  [Release] Philips 5990/12 modded firmware by vb6By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 140Last Post: 28th Sep 2015, 03:06
  5990 Firmware download?By marioval in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Nov 2010, 07:44
  Can Philips 5990 firmware be used on Philips 5992 Dvd PlayerBy peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06
  5990/12 firmware instructionBy Yugos in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2009, 19:14
  Phillips 5990 - How to revert back to original firmwareBy user111 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Feb 2009, 20:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
