Look at the end of the file too.
Results 781 to 810 of 949
Hello guys,
I would like to repeat my question again:
Do the last firmwares - vb6_v4 and v4_1 - (here and on vb6rocod's web site http://vb6rocod.euracks.com/dvp5990_37.php) support Cyrillic (CP1251)?
Thank you in advance! -
I was wondering if there was any update I could apply to the 3982 in order to get the wonderfully addictive long file names =D
I saw on Phillips site that that the 3962 shares the update but certainly don't want to assume a modified version the same applies
any assistance with this matter would be greatly appreciated oh wise ones ... -
With 4.1 firmware is there a max number of folders that player will read through usb?
I have external hd connected but only some folders with music appear.
Also, only 2 sub folders deep will appear in file browser. ie. root plus two sub folders.
Any1 else have this trouble?
What are the other firmwares with 8 lines per file browser page and 42 characters file names?
Thx -
It's still 300 folders with 648 files each, AFAIK. I don't think that has ever changed. If you bury the files too deep, then the unit may have a hard time reading them.
I just flashed to this firmware upgrade. I am not sure where things went bad, but I now have a defunct player
I read the description of how to try to bring this thing back to life, but it seems like it is a bit over my head now. In my house we have three laptops, no desktops. The oldest one was probably made in 2005, but it still doesn't have a serial port. Any way I can go about fixing this thing?
Do I have to have a serial port?
No, You can get a usb to serial adapter. But, It's probably better for you to purchase a new one. They are really cheap.Originally Posted by seylerc
Hi, I just bought 5990/F7 yesterday after read many great comments about it. I went through all the posts and did not find the firmware to be able to watch Vietnamese in srt files. Maybe I overlooked. If this mod firmware existed, could someone please give me direction? If not, can vb6rocod or some expert help me to write one? It's Unicode UTF-8, and usually in Arial or Times News Roman font.Originally Posted by vb6rocod
Thank-you in advance. -
Dunno if Vietnamese subs are supported. If not you could always use any of
Txt2Vobsub
AviAddxSubs
Subtitle Creator
to make idx/sub from your text files. -
Hello,
I just got a new Philips DVP 5990/f7. Wanted to upgrade.
Tried to open http://vb6rocod.euracks.com/dvp5990_37.php but got "page not found message".
Any suggestions?
Please help.
Thanks -
Yes, my primary site is down (and I don't know why...), but I have a mirror site:Originally Posted by sukhenkoi
http://vb6rocod.lx.ro/dvp5990_37.php -
Thanks a lot. It worked. I downloaded files DVP5990_37_vb6_v32_All_Logo.rar and DVP5990_37_vb6_v4_1.rar.
I will upgrade my DVP5990.
Could you please tell me about file DVP5990_37_vb6_v32_CP.rar. What it is for? Do I need it.
Thanks a lot again. -
Thanks a lot again.
So I guess I don't need it.
Thanks for all your help and work. -
@vb6rocod
A friend of mine needs a new standalone but the 3260 is no longer available. So I suggested the 3350/3360 (HDMI) but what about features? Is your modded firmware comparable in terms of idx/sub support? Thx. -
Question about MP3 playback, I find a long pause between the playback of songs.The player display states stop before starting the next file.Is there any way to shorten this time ?
Thanks -
Yes, by kicking Philips (support) in the nuts for allowing such an old bug to slip into a current official firmware.
"Question about MP3 playback, I find a long pause between the playback of songs.The player display states stop before starting the next file.Is there any way to shorten this time ? "
I guessing that this cannot be fix in a future mod firmware release -
Hi I think I screwed up my DVD player. I followed the instructions but where it says to follow the prompts. It never asked for any prompts but just said updating. The tray opened and after some seconds I pulled the USB out. now I have just a blue screen nad nothing works. even power on/off. Help please!!!
Can anyone tell me about the difference between files DVP5990_37_vb6_v32_All_Logo.rar and DVP5990_37_vb6_v4_1.rar? Which one do I need use to upgrade my Philips DVP 5990?
I used DVP5990_37_vb6_v32_All_Logo.rar, but now I am wondering if I had to use DVP5990_37_vb6_v4_1.rar.
Thanks a lot. -
Mmh, from what I've read the specs are very similar, only that the former has no Divx Ultra which don't rip to anywhere. Or do you mean in terms of your modded firmware? Otherwise I'd go with the 3360 since both have HDMI.Originally Posted by vb6rocod
I've a 5990 and I'm curious -- what's the big diff' between mine and the 3360?Originally Posted by TechflawsCheers,
Wanderlustus -
To All,
Think twice before upgrading your DVD player using DVP5990_37_vb6_v32_All_Logo.rar file.
Member Godey screwed up his DVD player trying to upgrade it. I had the similar issue with my new DVP 5990 when it never asked for any prompts but just said updating. I got lucky because i did not know what to do and waited about 5 minutes before I pulled out the USB drive.
However, in 4 days my DVP 5990 turned red. Now it shows everything in red color when I use HDMI output. I don’t think it has anything to do with upgrade, but I cannot return or fix it using my warranty because I upgraded the player.
So, think twice.
Thanks. -
That's relatively common with the 5990 (orange/red-appearing display when using HDMI), apparently. I've had it happen a few times to me, and I've even heard of people experiencing it with the stock/original firmwares.
All you need to do is unplug your 5990 from the wall (power outlet) for at least ten to thirty minutes, with the TV off, then plug the 5990 back into the power outlet, and turn the TV back on (HDMI). That should reset the player.If cameras add ten pounds, why would people want to eat them? -
As Far As We Can Tell - The Latest FirmWare (DVP5990_37_vb6_4_1.rar) Seems *Completely OK* When Tried With Three Different Philips DVP 5990 Players Manufactured On Different Dates (37/Mfg Aug 2008 + 37/Mfg Jan 2009 + F7/Mfg Sept 2009) - This Is All Related To Several Posted Hints By Others Suggesting A Possible Problem With Modified FirmWare And The More Newly Manufactured Players.
NOTES:
Details Of Our Testing Conditions, Procedures And Results Were Similar To Those We Described Earlier. -
Just unplug the DVD player from AC and plug it back in - all colors will be back to normalOriginally Posted by sukhenkoi
It has nothing to do with the firmware version.
BTW who is still selling 5990-s? My local Walmart has only 3982s...
I guess it's time to take care of BDP5005s
Per the last Post.. he is correct all we see is 3982's at the local wally world.. so is there anything we can do to improve the interface on them ?
[Release] Philips 5990/12 modded firmware by vb6
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 140Last Post: 28th Sep 2015, 03:06 -
5990 Firmware download?
By marioval in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Nov 2010, 07:44 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
5990/12 firmware instruction
By Yugos in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2009, 19:14 -
Phillips 5990 - How to revert back to original firmware
By user111 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Feb 2009, 20:31
