Page 18 of 32
FirstFirst ... 8 16 17 18 19 20 28 ... LastLast
Results 511 to 540 of 949
  1. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    I d/l the last divx firmware and ran into a problem after the install
    http://rapidshare.de/files/43881809/DVP5990K_75_vb6_v31_DivX_Logo.rar.html
    I have been using my player from the composite connector because the tv I am using doesn't have hdmi or component. Now my screen is just a blurr of green diagonal flashing lights.
    I can't retry with an older version because I can't see if it's at the proper screen to re-apply an older firmware.
    I hope that's what the problem is and that I didn't fry this thing. I've tried 3 others before that and didn't have any problems. I did it the same as before so don't know why this happened. caution is in order.
    There's not much to do but then I can't do much anyway.
  2. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    To all: Please don't blame the upgrade because it may just be an issue with me or my player.
    I'm documenting what happened and what I did for future reference.
    I reverted back to the previous version (8 line cd_logo) version by doing a blind reinstall. The problem persisted so I unplugged the unit for about 5 minutes and it reset. It's ok now back to where it was before.
    It wasn't what I thought that caused the problem. No matter what I did the tv was scrambly with colored diagonal lines. The sound was ok and the menu on the player was showing the no disc and when I inserted one it showed the avi track number. When I pressed play the time moved. I could pause etc... and there was sound but I was operating blind on the tv. I tried to bring up the menu but it didn't seem to work but I really couldn't tell. I have a component to vga switcher so I hooked it up and sent the vga signal to my projector but the signal was blank. I hooked the composite to the av input on the projector and tried the menu and this time it came up. I couldn't get to the reset option it just skipped over it. If I took the disc out of the player I couldn't even get the menu to show. It only worked when I had a disc and it was paused or stopped. Although dim and blurry on the edges I was able to read most of the menu items. It was set properly to NTSC and not progressive although that wouldn't have been a issue with my projector. Everything looked as it should but the video was still scrambled.
    At this point it is possible that if I had unplugged the unit it might have reset itself but I didn't know that at the time. That's when I decided to do a blind re-install of the previous firmware 2_3_1 CD_Logo. The update was successful but the player was still scrambled even after a power off and on. That's when I decided to unplug it for 5 minutes and as soon as I turned it on I was very happy to see the Philips disc logo.
    Whats weird is that although I could faintly see the menus on my projector, I couldn't get to the reset menu.
    I would have liked the divx logo but now that it's back I don't think I'l try it again just for that. If a really good feature is added I won't hesitate to try it again.
    @VB6rocod
    These firmware upgrades are fantastic and much better than the originals. keep up the good work
  3. Banned
    Dec 2008
    Russian Federation
    vb6rocod, can you make 8-line browser for 5996k/51?
    Thank you
  4. Originally Posted by LEONard3
    Thank you
    On previous page....
    https://forum.videohelp.com/topic355675-480.html#1932602
  5. Banned
    Dec 2008
    Russian Federation
    Thank you
    Thanks, it works but no Russian in file browser
  6. I've seen some flakiness in our player as well.. without the updates or with.
    Occasionally I only see the blue and green guns kicking in, so all the red is missing from the images.
    Yesterday, we saw a mostly black screen with some colored diagonal flecks. In both cases, unplugging the unit and plugging it back in cured the issues.
    I have a feeling there's a bad bunch of chips in some of the players.. walmart has a 90 day return policy, so I'll be returning mine for a replacement before that time runs out.
    For reference, I bought my player mid November.
    Gary Tabar Jr.
  7. Originally Posted by LEONard3
    Thank you
    Sorry about this.... I fix your problem... give a reply if is OK
    DVP5996K_51_vb6_v31.rar
    DVP5996K_51_vb6_v31_Philips_logo.rar
  8. Member philips599037's Avatar
    Dec 2008
    vb6rocod
    I see on your website that you updated the 3980K_55(75). I was wondering if there will eventually be an update for the 3962/37 since the firmwares are so similar?
    Thanks again for all your work!
  9. Banned
    Dec 2008
    Russian Federation
    Thank you
    These OK! Thank you very much!
    Jan 2009
    Canada
    Originally Posted by Gareee
    I think the only way to display longer filenames is with a smaller font. I know I'd love to have more then 20 as well.
    Where you set that up??
    Tnx
  11. Originally Posted by philips599037
    vb6rocod
    My last update is usefully for those who use subtitles in avi movie. It's your case?
  12. Member philips599037's Avatar
    Dec 2008
    vb6rocod
    That player sees its share of avi movies without hard coded subs so it would be nice to have a choice of colors and position.
  13. Originally Posted by philips599037
    vb6rocod
    Not Tested
    DVP3962_37_vb6_v2.rar
    After update RESET.....
    Seems to be a problem with this version ....
    Without Vertical Menu
    Load ORG Then All without menu:
    DVP3962_37_vb6_v21.rar
    Jan 2009
    Canada
    Hi, vb6rocod
    Thank you for your great work!
    I am a newbie here. I have some questions about my 5990/37.
    I got it in boxingweek and enjoyed it just a problem: I never get any Chinese subtitle even English. I did what I can do: Ensured that the file name extension of subtitle files is .srt, .sub, .ssa. Ensured that the subtitle file had the exact same file name as the movie file.
    What can I do now? Which your updated firmware is better for me?
    Thanks for your help!
  15. Originally Posted by cncaboy
    Hi, vb6rocod
    No Chinese subtitle here. Sorry for this.
    Jan 2009
    Canada
    Hi, vb6rocod
    Thanks for your rapid reply so much!
    But I can not get the English subtitle either. That is the problem.
  17. Originally Posted by cncaboy
    Hi, vb6rocod
    We Don't Know If This Entirely Answers Your Concerns, But We Tried Several Non-English Videos (AVI Files) And Found No Problems Whatsoever Viewing The Related English Subtitles (SRT Files). For The Record, We Tried Several Language Videos, Including Some In French. However, Videos (AVI Files) In *Any* Language, Including Chinese, Would Be Expected To Display The Related English Subtitles (SRT Files) Completely OK Of Course. We Used The Very Latest DVP5990_37_vb6_v31_DivX_Logo Version FirmWare (Our Earlier Test Report) For The Philips DVP 5990/37 DVD Player Under Conditions Similar To Those We Described Previously In Detail. (See Also Related TechFlaws And/Or VB6rocod Blogs If Interested.) Hope This Helps In Some Way.
  18. Member
    May 2005
    san diego
    I have my 5982 and 5992 , may i have a link for update firmware please. Thanksssssssssss.
    Jan 2009
    Originally Posted by emagon4523
    awesome.
    still wondering if you can make this puppy play .FLAC files with a firmware mod...
    NO,NO,NO,NO......
    gotcha - thanks for answering!
    still gonna have to load this firmware you've worked so hard on. flac or no flac!
  20. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    I just installed the DVP5990_37_vb6_v31_Philips_Logo.rar version, and did a reset - but the player doesn't seem to want to load my .ssa subtitles (same names as the videos, of course), regardless of whether I set the DivX Subtitle option to Original, All, or Same Name (yes, I'm paraphrasing the options, as I can't remember the exact names at this very moment. ) from a USB source. Haven't tried it with a disc, yet.
    It played them before I updated the firmware (from the custom 2.3.2 version, I believe.)
  21. Originally Posted by Ai Haibara
    For ssa, smi or sub/idx subtitle, use last version 2.3.2 (without "Load ORG").
    But for ssa or smi or style are disable by firmware (color, bold, position....).
    Visit my Blog or my site (mirror)
  22. Member
    Jan 2009
    Canada
    Hi
    I have installed DVP5990_37_vb6_v3. I love 8 lines but I have few questions:
    1. Is there any way of displaying longer filenames then 25 on usb ?
    2. How to display CD art all the time wile browsing files?
    - my always appears on bottom and I have to highlight it to show it
    and then disappears after selecting some other mp3 file?
    3. How to get to other folder other then scrolling all the way to the top of that folder?
  23. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Ah, okay. It's no big deal, though. I'll just go back to trying to convince my software there's nothing wrong with the .srt files I convert.
  24. Member
    Aug 2005
    Holland
    Originally Posted by ojelela
    Hi
    I haven't installed this firmware (yet), but with the original version all you have to do -while in the browser- is to touch REWIND: it will take you to the next higher level.
    Hope this helps.
  25. Member
    Jan 2009
    Canada
    Hi
    Hope this helps.
    Worked like a charm........Thanks a lot
  26. Originally Posted by vb6rocod
    Hi, vb6rocod
    FYI, I have tried to use vobsub (.idx + .sub) subtitle files and I can see Chinese subtitle.
    also, you can try this program to generate .idx + .sub if you only have .srt subtitle:
    http://www.trustfm.net/divx/SoftwareTxt2Vobsub.php?b2=1
    However, I really wish for Chinese display in the file broswer.. Does this support unicode?
  27. Member
    Jan 2009
    Canada
    Hi, vb6rocod
    Where is your location? I am in Canada
    I tried .idx+.sub before, but any subtitle appeared even English subtitle.
    So I do know what happen in my case.
    I checked the firmware version on my set and got the informations:
    Version 37.08.51.31
    SUB-VER 08.03.03.03
    8032 05.00.06.05
    Servo 93.88.00.02
    RISC 0A.00.03.01
    DSP 09.59.02.67
    Region Code 1
  28. Yes, I'm in Canada.
    Did you set the Subtitle "On" in the setting menu? Or did you try pressing the "Subtitle" button on the remote? Does it display anything? At least it should say Subtitle 1/1.
  29. Member philips599037's Avatar
    Dec 2008
    vb6rocod
    Not Tested
    I finally got around to upgrading and testing v21 and everything works great.
    Here's the DivX Logo version if anyone wants it.
    http://rapidshare.de/files/44984812/DVP3962_37_vb6_v21_DivX_Logo.rar.html
    Thanks very much vb6rocod and your new website looks great. Keep up the good work, it's very much appreciated!
    http://vb6rocod.xhost.ro/index.html
  30. Originally Posted by philips599037
    Thanks for "testing". For European model I make a version with RISC from 5990 (add support for wmv), also work vertical position. It's a good chance to work also for 3962_37... but is a "risk" to test without a "serial cable".
