Thanks! I installed and tried it. Noticed a few problem:Originally Posted by vb6rocod
1. Still not showing correctly in filebrowers. You said "nothing to do"....do you mean that it is impossible to show chinese in filebrowser?
2. I selected Chinese and sure enough chinese characters came out. However, it's coming out as words in random order. It seems that it's not mapping correctly.
When I use MTKReMaker.exe, in Font 3, each char has a number below it.
Do you know how the .srt is supposed to map to it?
my .srt fiels are encoded by codepage 950 (big5 encoding)....
how does it map for english char? If I have the char "A" in a srt file, how does the firmware translate that into what is displayed on screen?
For example, A in FOnt 1 is 66.... how does the srt file map to 66?
				Results 271 to 300 of 949
	I have the 5990_37 I am not sure about the version.Originally Posted by vb6rocod
 Thanks for the help.
	1. For filebrowser only "standard latin alphabet" unicod in range 0x0000 --- 0x007F that's from "factory".Originally Posted by rssmps
 2. For sub.
 Get MTKFontcreator , and open ini file:
 Here is an example:
 This is a conversion table. First is index and second unicod value (both in hexa).Code:Description=Windows Code Page 1250 Max=255 0x00=0x0000 0x01=0x0001 0x02=0x0002 ....... 0xFB=0x0171 0xFC=0x00FC 0xFD=0x00FD 0xFE=0x0163 0xFF=0x02D9
 You must "fill" this table (Max = ???), then make a font in MTKFontCreator.
 I find a table, but have more than 12000 value.
 http://web.mit.edu/afs/dev.mit.edu/source/src-current/third/libiconv/tests/CP950.TXT
 I can't help you more.
 Note:
 An alternate method is to use Txt2VobSub, transform srt in sub/idx file. It's very easy and fast (1 minute).
	OK, I downloaded MTKFontcreator and when I looked at the ini that came with it, I noticed that 950 is already in there. So when I opened it up with the exe, I saw all the characters appear.Originally Posted by vb6rocod
 I extracted the portion of the file that has all the chinese charac tables.
 http://www.mediafire.com/?sharekey=e88637dce9919c0ddd8b33b5aa27078d
 Is this what you need? what do I do with this?
	Somehow you must make a font using MTKFontcreator with ini file. I can't help you more, sorry... Maybe you can find a firmware with Chinese support for subtitles.
	So any help on the Turkish support. Thanks for the helpOriginally Posted by vb6rocod
 Z
	[s:356d075bba]Maybe I'm just blind but I looked through this entire thread but I can't find the firmware without the volume controls.
 The first page has the one with volume but where is the one without?
 And the other one is 1.2 not 1.2.1.
 I have a 5992 and the remote has the volume buttons. So I want the firmware without the repeat buttons changed.
 Can anyone find me a link?
 Thanks[/s:356d075bba]
 EDIT: Nevermind. I'm dumb. I didn't extract the file till now. Didn't realize it had both in the zip file. Thanks
	Already here:https://forum.videohelp.com/topic355675-180.html#1902896Originally Posted by zurnacibasi
 Or
 http://rapidshare.com/files/158491913/DVP5990_37_vb6_v1_2_1_CP1254.rar.html
	Thank you but that rapidshare link is not working. this is the error I getOriginally Posted by vb6rocod
 This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
 This limit is reached.
 To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information.
 If you want I can put it on a collector account so there will not be a limit.
 Thanks for the help
 Z
	I re-upload to other host. If you can to upload somewhere it's OK.
 http://rapidshare.de/files/41176703/DVP5990_37_vb6_v1_2_1_CP1254.rar.html
	vb6rocod
 hello!
 i read all this topic and saw that russian users asked you about help with DVP5996k/51 to do cyrillik support in file browser.
 Your DVP5996K_51_vb6_v1_2_1_1251.rar how i can understand support cyrilik in subtitles only, not in menu or file browser. if so can you help us please. many people in russian forums try to do it and we cant do it for a long time.
 we want to have russian menu, russian subtitle (it all we have in official DVP5996K_51.BIN) and insert cyrilic support for file browser. also your DVP5996K_51_vb6_v1_2_1_1251 have many usefully patches witch will be very usefull to us too. also it will be very good if lenght of file names in file browser will be 30 symbols. and in file browser window will be displayed more files with smaller text size than now
 So, if you can, please modify DVP5996K_51_vb6_v1_2_1_1251 that can be russian language in menu, subtitles and file browser.
 please help!
 will you help us?
	Update (tested) for DVP5990K_55 & 75
 OSD Font with outline
 Color for subtitle (text, background,outline)
 Vertical position for subtitles
 Load ORG Then All
 5990K_55_75_vb6_v2_2.rar
 [url]http://rapidshare.de/files/41180674/5990K_55_75_vb6_v2_2.rar.html[/b]
 For 5990_37 , same firmware like 5990K_55 , but not tested....
 DVP5990_37_vb6_v_2_2.rar (with and without volume on Repat keys)
 http://rapidshare.de/files/41180746/DVP5990_37_vb6_v_2_2.rar.html
	Something I noticed that no one has posted about...
 I have some DVD games (i.e Scene It, Amazing Race) and with the custom firmware, they don't function properly.
 I reverted back to the original Philips firmware and the games work fine. As a last resort, I tried the DVP5990_37_vb6_v_1 (the earliest custom firmware I could find) and I first got an error message but then it started playing the games.
 I'd keep the original firmware but I can't get by without the extra characters available with custom version. And the custom version just looks so much better too! Not sure if this is something that can be fixed. Thanks for all your hard work!
	Has anyone tried this 2.2 firmware for the 5990/37?Originally Posted by eugene2008
	Try this, is new version v2_2 with unicode support (ISO+Joliet and USB). Say thanks to shoora.Originally Posted by warplex
 DVP5996K_51_vb6_v2_2.rar
 http://rapidshare.de/files/41185871/DVP5996K_51_vb6_v2_2.rar.html
 BEFORE UPDATE SET OSD LANGUAGE TO ENGLISH.
 After, RESET. Open a "avi" movie change font, color and find optimal vertical position. Each font have different value.
 For OSD message in Russian I need some help. I must "map" your special char. in OSD font.
 You need to fill a table like this (all value are in HEXA)
 Use this picture:Code:0x100 = 0x413 -->>> unicod value .... 0x159 = ....
  Image Hosting Image Hosting
	I'm using DVP5990_37_vb6_v1_2_1_volume. The one without volume support. I couldn't get audio in dvd ts files until switching to ALL for digital audio setup in audio setup page. I forget how I ran cable to tv. Just a headsup for anyone having trouble.
 Great firmware VB6! and many thanks for this. Great improvement over original.
	vb6rocod
 this message, https://forum.videohelp.com/topic355675-150.html#1901506 from shoora and his vp5990_37_vp6_1.2.1_cp1251_usb.zip firmware i using now in 5996k/51
 There was russian support only for file browser.
 i download his firmware and insert fonts with russian language from our not-working modification of firmware (FONT1 wich used by menu (also i inserted all our fonts so subtitles can work too i think), FONT4-wich used by file browser already was in shoora's firmware).
 so,now, russian support in shoora's firmware - everywhere (filebrowser, menu(OSD)), subtitles was not tested because it is not interesting for me (maybe only for me...) but it's for 5990|37 not for 5996|51 and it's
 so no MAP needed
 i download
 vb6rocod wrote:
 For DVP5996K/51.
 Suport chirilic only for subtitles, not for files (filebrowser).
 http://rapidshare.com/files/154903307/DVP5996K_51_vb6_v1_2_1_1251.rar.html
 like in shoora's firmware i change same fonts in your firmware. So, russian language now in your firmware in menu(OSD), and subtitles as you say i posted a little higher. But file browser don't have russian support.
 so, map for russian characters don't needed too.. (am i right?)
 DVP5996K_51_vb6_v2_2.rar i don't tested yet
 If you wish, i can send to you DVP5996K_51_vb6_v2_2 with our fonts.
 I test DVP5996K_51_vb6_v2_2 this evening and then post here about result.
 vb6rocod, thanx for help!!!
	Hi !
 I just tried the new 2.2 firmware for dvp 5990/37 and it works great.
 But I really need the romanian language , please vb6rocod ,could you help me please ?
	I applied the latest firmware to my 5990 and it seems the USB port remains powered on even when the player is shut off now. My external hard drive keeps spinning all the time. Is this normal ?
 The new firmware is supposed to increase the amount of characters in the titles to 40 but it seems it stops at about 13 characters. Does anyone else notice this ?
	For Philips apparently cause that's a bug in the original firmware. The only thing you can do about it is complain to Philips support.Originally Posted by blueribb
 It's 40 from disc and 25 from USB.Originally Posted by blueribb
	Sigur merge bine? Nu se impiedica la filmele avi?Originally Posted by Cris69
 Pentru subtitrari (avi)
 DVP5990_37_vb6_v_2_2_1250.rar
 http://rapidshare.de/files/41194892/DVP5990_37_vb6_v_2_2_1250.rar.html
 Sarbatori fericite.
 I have a WD Mybook drive which shuts down after 10 minutes of being paused. I actually will pause the movie and come back later to finish. It takes 5-10 seconds for the drive to spinup when unpaused.
	I don't understand your statement. When you pause the player for a certain amount of time, the player will shut off - not your hard drive. My Maxtor 60gb mini hard drive has an LED which remains on and you can hear the platter spinning even when the Philips player is shut off.Originally Posted by Tripper_
 I never turn my DVD player off. At night, if I'm tired, I simply pause the player. After approx. ten minutes the drive spins down and the hard drives head parks. The drive is essentially off. I assume that the WD Mybook drive senses that no data is being transferred and shuts down. In the morning, all I have to do is press play and the audio/picture stutters for a couple of seconds and resumes.
	---Originally Posted by vb6rocod
 PROBLEM WITH NEW VERSION ("vb6_v_2_2") FIRMWARE FOR PHILIPS DVP5990_37 DVD PLAYER?
 PRELIMINARY TESTS:
 ( NOTE: These Tests Are Similar To Our Earlier One, For Version "vb6_v2," Posted "Nov 25, 2008 17:06" - https://forum.videohelp.com/topic355675-180.html#1911417 )
 After Installing The NEWEST VERSION FIRMWARE ( Version "vb6_v_2_2" Of The Newly Available "DVP5990_37_vb6_v_2_2.rar" File Downloaded From http://rapidshare.de/files/41180746/DVP5990_37_vb6_v_2_2.rar.html ) To Our Philips 5990_37 Player And After Performing The Usual "Default Reset" And "Setup Configuration Procedures" (Involving "Component Video," "Progressive Scan Mode," "Digital Coaxial Audio") For Our Present AV System ("Sony KDL-52W3000 TV" & "Yamaha HTR-5790 AV Receiver" & "Philips DVP5990_37 DVD Player"), DVD+R Discs (Verbatim) With MP3 Files As Well As Similar DVD+R Discs With NTSC MOVIES Or Even Similar DVD+R Discs With PAL MOVIES Do NOT Seem To Be Recognized At All By The Philips DVP5990_37 DVD Player And Inserting These DVD+R Discs Into The Philips DVP5990_37 Player Produces A COMPLETELY BLANK SCREEN.
 PLEASE NOTE: The OLDER VERSION FIRMWARE ( Version "vb6_v1_2_1" [*Without* "Volume" On The "Repeat" And "Repeat A-B" RC Keys] Of The Earlier "DVP5990_37_vb6_v1_2_1_volume.rar" File Downloaded From http://rapidshare.com/files/144682875/DVP5990_37_vb6_v1_2_1_volume.rar.html ) Seems To Work *COMPLETELY OK* In Every Way And Was Successfully Re-Installed And Restored Back Into Our Philips DVP5990_37 DVD Player.
	Pt. vb6rocod
 Am testat si azi si merge f bine la filmele .avi,
 dar nu vrea sa recunoasca DVD+R,in schimb recunoaste DVD+RW.
 Incarca toate subtitrarile ( si cele care au nume diferit de al filmului ).
 Multumesc mult de tot si iti doresc CRACIUN FERICIT !
	Precum vezi ultima versiune e destul de "controversata", si sincer inca nu m-am prins de ce. Daca ai probleme cumva pune versiunea anterioara:Originally Posted by Cris69
 DVP5990_37_vb6_v1_2_1_1250.rar
 http://rapidshare.de/files/41203002/DVP5990_37_vb6_v1_2_1_1250.rar.html
 De asta nu s-a plans inca nimeni.
	Please post all questions and answers in english, so all nationalities can read and understand.
  [Release] Philips 5990/12 modded firmware by vb6By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 140Last Post: 28th Sep 2015, 03:06
  5990 Firmware download?By marioval in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Nov 2010, 07:44
  Can Philips 5990 firmware be used on Philips 5992 Dvd PlayerBy peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06
  5990/12 firmware instructionBy Yugos in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Dec 2009, 19:14
  Phillips 5990 - How to revert back to original firmwareBy user111 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Feb 2009, 20:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
