Right now I'm running a peer to peer (3 desktops and 1 laptop) and I want to start running a server environment. I have an older GATEWAY TBR2 PIII 450 that is just lying around that I was thinking of using as a server. Although it doesn't fit the recommended specs, it is well over the minimum requirements. In your opinion, what are the major draw backs of using a desktop as a server? Not just the desktop that I mentioned, but any desktop.
I do understand the way to go would be just to purchase a dedicated server, which I plan to do in the future, but right now is just not in the budget.
Results 1 to 13 of 13
"server" is such a broad and vague term anymore.
what kind of server? What exactly will you be using it to do?
Print server? Media server? Web server?"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Well, actually I asked for the draw backs of using it as a server of any type. Does the pc's specs allows it to be used as each of the three you named or all three? I wouldn't be to concerned about the print server right now, but I would be interested in using it as a File and/or web server.
How many clients would you have connecting to it at any given time? And how would they connect (ethernet, wireless, remotely etc)? Which server software (or even OS)?
John Miller -
File server yes but is it electrical power efficient to be running this 24x7?
Explain your file server needs. Want to gang up old small drives? Want to run a Linux Samba server for Windows*?
Web serving depends on many things starting with upload bandwidth for your current internet connection. Again this old PC is going to be drawing power and adding to your air conditioning load 24x7.
* I solved this problem by copying all old small drives to one 500GB drive that sleeps unless accessed. I have several other 200-500GB drives that I only power up when needed.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Let me state this will be running at my home as a hobby/hands-on. I want to use window server 2003. I have 3 desktops and 1 laptop. I had plans on using a 500GB HDD. This will be an ethernet network.
You could do this by sharing a drive from one of your active PC's. Why do you need this "server" running?Originally Posted by Eyecan'tcode
If you just want to simulate a business network, go for it.Recommends: Kiva.org - Loans that change lives.
It will be so slow as to be barely usable. Likely a unit that old won't support a large hard drive. For a unit just to host and share files, XP pro would be a better choice, or W2k. Pretty close to a total waste of time and effort, that thing is a doorstop.
I've had many customers literally throw away much newer units, I've got a couple of 1.4 - 1.8 Ghz units sitting in the garage heading for the dumpster right now. -
Invite a few close friends over and say some kind words of remembrance for that old dog. Then put it out of its misery and bury it.
The processor speed keeps it from being a RIP server or similar encoding-type slave (streaming media for instance). The PCI bus would be the deciding factor of making it a file server. I'm guessing it doesn't have onboard GbE so you'd want a dual-GbE NIC to support plenty of bandwidth on your network (of course you'd also need a GbE switch). You would also probably want a PCI-X slot to support a multi-port storage controller and plenty of room for HDDs. Pack it full of memory (up to the board/OS limit) so that it can buffer more data for the NIC. File servers don't use much CPU so your P3 is fine.
Since file servers are often meant to run headless you can set it up then move it to a utility room or closet to isolate the noise/heat. You just need network cabling and power present then you can simply remote into it for maintenance.
I still use 9-year old Tyan Tiger MP as my multimedia server. It can still hold its own against some current economy platforms in fact. I'll probably continue to use it until it dies but it will gradually decrease its profile in my network to less important roles as that day approaches.FB-DIMM are the real cause of global warming -
Well it was just a thought. I won't throw it away though; I'll just put a hdd in it and give it to someone I know who needs pc.
I use a 366 celeron, 128M ram, 20Gig HD for my ftp/basic html server. It does the job more than adequately as a LAMP server.
When browsing the php-javascript pages, I notice no difference from your average web page speed. Upload (download to you) speeds are consistent with my max upload.
Unless you're running a business, 10-year-old equipment will work just fine. Hell, I was running a server off my (200Mhz) Dreamcast for a bit, and even that ran smoothly. -
I have a lightning fast Samba file server running Ubuntu Linux (7.10) on an AMD 2.66GHz. 2GB of RAM. I have six PCs accessing it. Since this is the home environment, usually it is not being hammered by everyone at the same time.
Edit: After reading the above post, I think I will move my server over to a 700MHz machine I have sitting around. I've suspected for a while that it was overpowered for a server of this nature. And besides, I can use that 2.66GHz for something else.
Darryl
Best media player for an older pc
By frieday in forum Software PlayingReplies: 15Last Post: 29th Jun 2015, 07:10 -
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 16:25 -
Coloring on older DVDs
By lilblu in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2009, 11:17 -
Does anyone still have the older build of SUPER?!
By Nintendo Fan in forum Video ConversionReplies: 11Last Post: 21st Jan 2009, 18:29 -
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18
