I have avi.net on a my new pc but it doesn't work on this vista machine for some reason. It says that no codecs are installed. Have have when toinstalled both on my pc. Please help, i am a newbie and not much knowledge on this subject. It did work fine on my old xp version pc. thanks so much.
Have you installed the xvid codec or the divx codec?
Originally Posted by Bobtail60
I e-mailed CloneAD via the website asking whether an update or patch is planned but got no reply. Does anyone with their ear to the grapevine know if there are plans to make this program compatible with Vista64 or do I need to think about installing it on my XP VM? I'm using AutoGK at the moment but the results aren't quite as good and I miss the ability to trim overscan crap from the borders of the source video right from the GUI.
Looking for a USB Video Capture Device I can work with in VB.Net
By Snakebyte1 in forum Capturing and VCRReplies: 0Last Post: 6th Oct 2011, 07:59 -
Looking for something like the WD HD, but would like net work connectivity
By Jhon in forum Media Center PC / MediaCentersReplies: 7Last Post: 18th Apr 2009, 08:05 -
Canon hg20??? getting it to work on PC Vista
By smithmackay in forum Video ConversionReplies: 6Last Post: 30th Mar 2009, 12:36 -
FAVC does not work in VISTA !!!
By gonwk in forum Newbie / General discussionsReplies: 7Last Post: 1st Mar 2009, 03:48 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 07:22
