Results 1 to 10 of 10
    Apr 2008
    Australia
    I recently downloaded a mkv video file. Attempting to remove useless streams on the mkv file using the latest version of mkvmerge, error messages appear about unable to locate decoder specific config data and something about a return error 2 Using mkvdiag I notice the file was compiled with mkvmerge 1.0.1!!!! I was thinking to attempt to use the older version but since the files are not available, I am stuck. Can someone please either help me solve the decoder specific config thingy or compile and give to me the older version of mkvmerge. Thanx a lot.....
  2. Originally Posted by theninger
    I don't understand. Why don't you use the newest version? The link is given in Videohelp's tools section
    Apr 2008
    Australia
    The newest version wouldn't work....
  4. Try extracting with mkvextractgui, then use mkvmergegui
    Apr 2008
    Australia
    the video has a variable frame rate and if I extract the video file then it becomes out of sync with subs, audio etc.... Thanx for the help so far
    Apr 2008
    Australia
    hmmm someone please help me on this one
    Apr 2004
    Miskatonic U
    mkvmergeGUI allows you to set the playback framerate. Set this to what it should be for synchronized playback and see how you go.
    Read my blog here.
    Apr 2008
    Australia
    Let me try it. Will get back ASAP
    Apr 2008
    Australia
    Worked like a charm. Thankyou. Baldrick, I've looked for earlier version of mkv on this site for quite sometime but couldnt find any version before 2.0. How did u manage to locate the 1.5 version?
