I am using Tmpgenc xpress 4.0.
I would like to know Image Resolution & aspect ratio value.
MediaInfo 0.4.0.1:
codec: DivX 5
W640 x H480
Aspect Ratio: 4/3
Frame rate: 29.97
Should I set it NTSC? Is it depend on source file or TV?
Drop down menu don't have 640x480. What should I set? Should I set it highest or customize it to 640x480?
There are many 4:3 inside aspect ratio like pixel 10:11 (NTSC4:3) , display 4:3 and so on. What should I set?
convert avi to highest qty mpg format then use tmpgenc dvd author for dvd output.
I am now following guide at https://forum.videohelp.com/topic249135.html?sid=54dbba791978ea2aa34c112def09e480 -
You can feed AVI files directly to TMPGEnc-Author, no need to use Express at all. It will default to the correct settings too, or you can adjust for best quality.
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 15:17 -
Resolution and Aspect ratio
By Mrsash in forum Video ConversionReplies: 4Last Post: 19th Nov 2009, 17:37 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 08:23 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 04:06 -
DVD to Ipod resolution & aspect ratio
By lemmy999 in forum Portable VideoReplies: 1Last Post: 18th Jul 2007, 14:47
