Just wondered if anyone knows or if anyone has tried connecting a Pioneer Hard drive to a computer, and if so is it compatible (file format). Would like to copy everything off of the hard drive to my computer and a direcct connect is much faster that one DVD at a time.
And how would you do this? Take the Pioneer apart and connect the HDD to a PC EIDE cable under XP?
http://www.kiva.org/about -
Unlike cable/sat DVR boxes, the Pioneer disk is unlikely to be encrypted. The question is if the disk uses PC EIDE/Partition/FAT formatting or other.
I was just asking if you expect this over USB.Recommends: Kiva.org - Loans that change lives.
No not over USB. I tried a flash drive just to see if there was a way to copy to it but it doesn't appear so.Originally Posted by edDV
Is my computer compatible?
By Immensible in forum Capturing and VCRReplies: 9Last Post: 17th Nov 2011, 16:36 -
dvd copied from HDD wont work on other players or computer??
By wundahoss in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2010, 16:34 -
Will my old WinXP computer be OK with a 1TB internal HDD?
By FulciLives in forum ComputerReplies: 9Last Post: 21st Feb 2009, 19:56 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 12:38 -
FIREwire HDD, NOT in my computer,update NEW acomdata HDD works great
By theewizard in forum ComputerReplies: 22Last Post: 20th Jul 2007, 01:01
