I have a problem with a tape I'm trying to transfer, I've tried to 2 VCR's and each give a different problem. The first picture is from the Mitsubishi 2000u with the TBC & DNR off.
If I use the Mitsubishi with the TBC or if I use my other vcr the JVC 4000u I get this:
doesn't matter what I turn on or off on the JVC either I always get distortion on the top of the screen. I should mention the tape always sounds strange while rewinding almost like a grinding noise.
The first picture (Mitsubishi 200u) shows evidence of DNR, specifically temporal smoothing. I can see the tale tell shadows from at least three previous frames. Are you sure DNR is turned off?
Darryl -
Yeah, the Mitsubishi only has a single button for TBC+DNR I'm feeding it to a JVC DR-M100
You'll have to go with the lesser of evils.
Yeah I kinda figured that, I think I'll see if I can hunt down another copy of the tape and see if that will hopefully fix it before I give up all hope. Thanks for the looking at this guys, I appreciate your wisdom.
Ghosting effect
By nikgelfi in forum Capturing and VCRReplies: 27Last Post: 6th May 2011, 08:38 -
Ghosting while capturing
By kokojib in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 11:34 -
Shifting and Ghosting
By NightFire in forum RestorationReplies: 11Last Post: 28th Jul 2008, 19:29 -
How do you fix ghosting?
By zanos in forum Video ConversionReplies: 4Last Post: 27th Apr 2008, 01:21 -
Curious about cause of this ghosting(?)
By kiwiusa in forum RestorationReplies: 12Last Post: 17th Feb 2008, 22:01
