Should people disable one of their brightness/contrast settings (either hardware or software) and only enable the one that looks better?
I just bought a new computer about half a year ago. The whole time I was using my computer I was never quite satisfied with the image quality of it. The monitor is a Compaq LCD monitor.
Anyways, when going to websites with dark backgrounds, I could see some movements in the dark areas of the screen. I'm unsure what this was, but I just figured it was a sign that my monitor was crap.
Today I was fed up and decided to tinker around with my onboard graphics settings through 'display properties' in Windows XP. I went to the 'color correction' tab and noticed that there were pre-set brightness and contrast settings already enabled through my computer's software. Immediately after seeing this I thought of something.... I thought "My monitor having it's separate hardware brightness/contrast settings turned on at the same time as my software brightness/contrast must have been the cause of the horrible picture quality."
I decided to turn the software brightness/contrast to 0. After doing this I decided to set my hardware brightness/contrast to what I found desirable. Well, the thing is that I could not set my monitor to look good after putting all of the bars to 0 in the software settings. So then, I decided to do the opposite. I turned the values on my monitor to 0 and went into my software brightness/contrast settings again. After setting the software bright/contrast values to their default numbers, the picture on my monitor looks fantastic!!!
So now I have a question.... Will the software settings always look better, or not?
I have a feeling that enabling both hardware and software brightness/contrast at the same time will always have undesirable effects on the monitors image quality.
You typically use a combination of the two. Nvidia (and likely ATI) drivers have a calibration tool that walk you through adjusting all of your monitors settings for correct brightness and color levels.
Google is your Friend
Correcting saturation, contrast, brightness, etc...
By takearushfan in forum RestorationReplies: 28Last Post: 21st Sep 2011, 23:32 -
Need Editor for Contrast, Brightness, Color Saturation
By HorseTears in forum EditingReplies: 1Last Post: 15th Dec 2009, 11:32 -
Video editing of brightness and contrast?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 6th Feb 2008, 19:31 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 23:26 -
Fixing brightness/contrast on a DVD
By Salva Veritate in forum EditingReplies: 4Last Post: 7th Oct 2007, 21:05
