What's the difference between standard and wide? It's not 4:3 vs 16:9?Originally Posted by cal_tony
From the reader reviews at Amazon.com it looks like the E5500 has the same problem.Originally Posted by cal_tony
Results 31 to 35 of 35
Jagabo,
With my TV, having a 4/3 video inserted in the 5960 and having it set to a 16/9 TV receiver, I get a standard 1080 pic that fills the screen. My TV remote has a format button to change the appearance of whatever its receiving. so when I press this the only other format it will convert it to is 'wide expand'. It kind of seems like a wide zoom.
Press the 5960 'upscale' button so it gives a 480p image still thru the HDMI and everything is fine. I once again have all six settings on my TV remote.
and I do get a 4/3 pic thru HDMI. It's just not upscaled.
Maybe this problem is only related to the way the 5960 works. With the XD-e500 pressing the format button on my TV may give me a 4/3 1080 pic. I don't know. Posts on the Amazon site re. the XD indicated this was also a problem on some TVs and there was no workaround.
With my Tosh. HDDVD A3, it also has the ability of the TV set to change the
format of the pic. But even though settings on the TV remote are the same the picture at 1080 standard is 4/3 and the other setting 'wide expand' is just the normal fill up the screen pic.
Having done all of this, I'm still not sure how the XD will work re. 4/3 or 16/9. I will just have to get one and try it out.
The one thing I am sure of though is that the 5960 will not give me an upscaled 4/3 pic no matter what settings I use on my TV or on the 5960.
Tony -
ALL hi-def should be widescreen.. that's what your TV thinks, so offers no options when it receives a Hidef signal over HDMI. SD can be either Ws or PB, so you get the options (AFAIK)?
Rabid dog,
Not so fast. When the PS3 or the Toshiba HDDVD A3 player sends a 4/3 thru the HDMI, my TV sees it for what it is. 4/3. And plays it that way. It's the 5960 and it seems like the XD-E500 that just don't send the right info to the TV.
With all that stuff about device and TV handshaking thru HDMI, maybe they're just not into handshaking
Tony -
I agree. The issue is with the XD-E500, Toshiba should of never released this device without resolving this issue first. I hope they are working on a firmware update to fix this problem.Originally Posted by cal_tony
It otherwise puts an enormous blemish on a device that has excellent possibilities.Do unto others....with a vengeance!
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Philips DVP5990/37 and Toshiba XD-E500 NTSC to PAL question
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 19th Feb 2009, 10:12 -
Toshiba XD-E500 It works
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Dec 2008, 02:16 -
Toshiba XD-E500 Upconverting DVD Player Released Today
By ejai in forum Latest Video NewsReplies: 8Last Post: 25th Aug 2008, 01:38 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57
