I have an iPod Classic 6th gen on which I want to put some Animé on.
But my Anime are mostly in OGM or MKV format and multiaudio.
In most cases the first language is set as Japanese.
Now when I convert the files with Xilisoft is uses Japanese as output audio without subs, but I want the English Audiostream.
Do you guys/girls know a program in which I can select the audiostream to be used as output audio? I know for a fact Xilisoft can't do this.
I hope I'm clear with this. I'm a Dutch guy, so If you don't get it please ask and I'll try to rephrase and explain.
You can just remove the unwanted audio with mkvmergegui . Checkmark the stuff you want, uncheckmark the stuff you don't want, make a new .mkv. Then feed the new .mkv into whatever program you want. xvid4psp is a good easy choice to use with ipod preset
cheers -
For OGM, I usually just demux all the streams, anyway.
However, you can also delete unwanted streams in an OGM using VirtualDubMod. I think AVIDemux, and others, should be able to do that, too, though I don't have any OGMs around to test.
(I think there was also an mkvmerge-like suite around for OGMs as well, but I don't remember what it was.)If cameras add ten pounds, why would people want to eat them? -
Thanks a lot. This MKVmergegui is great, but I'm not going to use the program xvid2psp. I'm already use to Xilisoft video Converter Ultimate. I'm also going to try and see if it also works with OGMOriginally Posted by poisondeathray
I think I'm going to try VirtualDubMod, it sounds familiar to me, but I don't know from where.Originally Posted by Ai Haibara
Thanks a lot, both of you, you guys really helped me out big time
Grtz
edit
MKVmerge GUI also works for OGM, only it turns the files to mkv files after muxing. But that's OK, I can play 'em both. -
lolOriginally Posted by ironmaidens
probably from millions of posts...Originally Posted by ironmaidens
that's taking the longest possible route.Originally Posted by ironmaidens
an ogm will most likely at the most need a simple remux and audio transcode.
assuming no further psp restrictions present. (and i don't know exactly what the psp expects.)
but i do have a batch for doing ogm to avi in the guides.
tripp"I'll give you five dollars if you let me throw a rock at you" -
look at my joining date, dildo. 8) :P I joined todayOriginally Posted by 45tripp
Well, it works for me. I just do exactly the same as with an MKV file.Originally Posted by 45tripp
a short route actually, unless you can show me otherwise
you just started reading today?Originally Posted by ironmaidens
you just started surfing today?
there are many silent readers, and if you've read anything video related at all,
chances are high you've read of vdub and it's variants.
ergo, it's likely to ring a bell.
i canOriginally Posted by ironmaidens
https://forum.videohelp.com/topic334918.html
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to open MP4,MKV,WMV,RM,MOV,OGM with any editor,encoder
By Baldrick in forum User guidesReplies: 78Last Post: 24th Feb 2011, 10:53 -
mkv to avi troubles.
By joonshik in forum ffmpegX general discussionReplies: 3Last Post: 10th Mar 2010, 18:32 -
MKV conversion troubles
By Alexstarfire in forum Video ConversionReplies: 3Last Post: 7th Mar 2010, 15:10
