I got a RealMedia VBR movie downloaded from the website but neither play it with the PowerDVD in a computer nor do it in a DVD player. Does anyone know how to play the RealMedia VBR in a computer and whether it is possible to convert the RealMedia VBR into the DVD format?
well, the real player will play it...
try this
https://www.videohelp.com/tools/Real7ime_Converter -
Drag 'n' drop the RMVB into ConvertXtoDVD version 3 and it'll spit out a nice DVD.
I use VLC media player, just add these files in the VLC media player plugin folder. {I added from Mplayer's extra codec packs} The codecs work. I've already tried it on my computer.
real%20media%20codec%20files.rar -
You may have already discovered this, but highly compressed, proprietary formats like Real VBR are are difficult to convert.
ConvertX does a fair job and and some other similar converters may work. I use VirtualDub Mod and AviSynth to open the Real VBR files using a small AVS script. Then I convert to whatever AVI type format I want. You could also probably frameserve the output directly to a MPEG encoder if that's your final output. That's likely what ConvertX and other converters will do. Using AviSynth and VD gives you a lot more control of the final product. I find this the best way to achive the best quality from those type of files.
One way to open Real files: https://forum.videohelp.com/topic289872.html
Convert Realmedia to AVI(DivX50)
By ashwin.terminator in forum Video ConversionReplies: 0Last Post: 15th Apr 2009, 13:01 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 11:16 -
How to Convert Popular Video Formats to RealMedia Files (eg: rmvb)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 22:09 -
Convert VBR to CBR
By Pariah69 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 12:32 -
How to play .ram RealMedia using AVISynth?
By Mark001 in forum Video ConversionReplies: 0Last Post: 10th Jun 2007, 09:55
