Hi,
just curious to know if using Firewire to transfer video from a sony minidv camcorder to the PC does it manipulate the data in any way ? Any kind of filtering or compression or anything ?
Also I wanted to know if I want to play the video off the camcorder using the firewire connection (and not the S-Video) on a TV monitor, what are my options ?
Are there TV sets out there that can take a video input over firewire or 1394 ?
Thanks!
Yes, it puts it into an AVI file and adds some AVI structural information. If you're using type 2 DV AVI it also makes a second copy of the audio and adds that to the file.Originally Posted by Movie-Maker
No.Originally Posted by Movie-Maker
Yes.Originally Posted by Movie-Maker -
ok it's good to know it doesn't change the original video data in any way and just 'arranges' it into a different structure.
would you mind giving me some pointers in the direction of such TVs ? Just look for a 'Firewire' or '1394' input ? Is HDMI same thing or atleast backward compatible to firewire/1394 ? -
HDMI is completely different. I don't know what models have firewire ports although I've read about it here and there. Some of the Sony models have it, I think. They call it iLink.
Some early HDTV sets had IEEE-1394 inputs intended primarily for connection of DVHS machines using MPeg2_TS but some also allowed DV format connections with camcorders. Since ~2004 the TV industry has moved away from IEEE-1394 (compressed) to HDMI connections (uncompressed protected with HDCP).
Meanwhile HDV and AVCHD camcorders have added analog component and/or HDMI connections for output to an HDTV. That left older SD DV/DVCAM camcorders with only S-Video as a usable TV connection unless you use a computer or external DV to HDMI or analog component conversion path.
Normal work flow for camcorder DV is IEEE-1394 transfer to a computer DV-AVI file, then DV format editing, MPeg2 encoding and authoring to DVD. That is an all component digital path to the DVD player output. A DV format archive can be saved back to DV tape or to a hard drive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Canon HV20/30/40 IEEE 1394 connectivity issues with Windows XP
By E_D_George in forum Newbie / General discussionsReplies: 19Last Post: 4th Mar 2012, 14:32 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 12:27 -
No Firewire/1394 on newer laptops ?
By Movie-Maker in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2009, 18:01 -
Small Notebook with Firewire Connectivity
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2009, 14:56 -
DVD player with Firewire (1394) out
By PizzaPete in forum Capturing and VCRReplies: 9Last Post: 23rd Oct 2008, 01:05
