Are there any burners out there with SATA that will allow the use of cartridge-type DVD-RAMs without having to remove the disc from the cartridge?
Possibly, but I don't know of any off hand. One of the few cartridge type burners around is the Panasonic SW-9576-C, but it's a PATA burner and fairly expensive.
You may be able to find a SATA version or a external enclosure that can use a PATA burner, but has a SATA external interface.
A page from Panasonic: http://www.panasonic.com/industrial/computer/storage/optical/models/SW9576C.asp -
I already have one of the Panasonic PATA units. I am planning out my next system rebuild, and would like to go to strictly SATA. Plus, the Panny burn speed is very slow. I
Could someone recommend a good SATA CD/DVD burner?
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Feb 2011, 23:41 -
sata dvd burner in older computer
By victoriabears in forum DVD & Blu-ray WritersReplies: 1Last Post: 1st Apr 2010, 01:28 -
Which SATA DVD Burner is best for QUAD System?
By mlong30 in forum DVD & Blu-ray WritersReplies: 20Last Post: 12th Sep 2009, 03:50 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
advice on an SATA dvd burner?
By lumis in forum ComputerReplies: 4Last Post: 19th Jun 2007, 04:09
