Hi all, I wonder if it is possible to burn shorter HD (720p) clips on standard DVD and play it on blu-ray device such as PS3? I ask this since blu-ray burner is still very expensive. Thanks in advance for your help.
Is it possible? Yes. Others have reported being able to play BluRay format burned to DVD discs (both single and double layer) on some BluRay players, including the PS3.
Does it work every time? No. Various factors don't lead to 100% success.
Media quality might play a role (that means some disc brands might work better than others) and frankly BluRay players are just bitchy about what they play back from burnable media. -
Yes it's possible ,and as stated above not 100% successful every time,in which case,you need to re-encode to make it PS3 compatible..But give us some details on a sample clip,so we can offer some help/tips...
Use MediaInfo...." Who needs Google, my wife knows everything" -
Thanks for the info. I have clips about 30m in different format like WMV, DIVIX (1280x720) , etc. So I just need to re-encode it to the blu-ray format? What tools should I use to author it to the DVD?
You can use a commercial blu-ray software like ArcSoft TotalMedia Extreme or try the free RipBot264. Just burn the output on a DVDr instead of blu-ray media.
And this is not blu-ray to avi/mkv, it's more blu-ray authoring/converting. Moving you.
OK many thanks, will check out the free software as I don't do this much!
DVD content on Blu-ray
By michcio in forum Authoring (Blu-ray)Replies: 4Last Post: 10th Mar 2012, 07:45 -
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 08:52 -
HELP: DVD Rip and convert 4:3 content to 16:9
By propman07 in forum Newbie / General discussionsReplies: 15Last Post: 28th Apr 2010, 05:39 -
DVD with VCD content in Windows 7
By macnab in forum Authoring (DVD)Replies: 1Last Post: 2nd Dec 2009, 03:51 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36
