I have a Canon HV30 that I cap using HDVSplit and I end up with a .m2t file. I want to
1) Burn them on to Blu-Ray/DVD
2) Convert them to flash movies (I use RIVA FLV Encoder for this and seems to work good, I just need the m2t in mpg or avi or some other format first)
3) Maybe have a format thats medium quality to play back in other people's pc. (Something that may be a pretty big download, but better quality than the FLVs)
What format should I convert the m2t to? Do I need to convert them before burning them or will the authoring software accept m2t format? Will one format be better for interlaced and one for deinterlaced? Any other help would be really appreciated.
1) I think you can use tsmuxer and mux into a blu-ray compliant standard. Or try Ripbot264 or ArcSoft TotalMedia Extreme.
2) I would convert to mp4 with h264 and aac, it is supported by latest flash. Try convert using Xvid4PSP. See my https://www.videohelp.com/guides/how-to-convert-any-video-to-high-quality-flash-mp4-wit...te-id1082#1082
3) Convert to avi xvid or mp4 h264 using Xvid4PSP again.
Convert .m2t HD-DVR file to .ts for Blu ray burning??
By tackdriver in forum Video ConversionReplies: 15Last Post: 19th Feb 2012, 12:25 -
Convert m2t to avi using AviSynth
By Landrew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 47Last Post: 7th Aug 2008, 21:56 -
Help with m2t to DivX
By Garde in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 19th Dec 2007, 12:21 -
What is a M2T file? How do I...?
By Sal C in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Oct 2007, 16:17 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03
