Could someone tell me why the "WRITE CD" is always greyed out
when I tried to build a VCD or SVCD on Nero. I did drag and drop
the Mpeg file into the MPEGAV directory, but nothing happen after
that, I cannot start the burn because the WRITE CD from the file menu
or the task icon are both greyed out. I am pretty sure the mpg
file I provide is VCD compliant, since I can create an image using :cry:
VCDImager. Anyway, Nero did not complain either, just nothing
happened! I tried to reinstall Nero, but that does not help either. I
believe I had a SVCD build once. Creating a ISO disk is never a
problem either. Nero does not seem to have any technical help that
I can send message. Any help would be greatly appreciated.
by the sound of it you need to get a update for your nero or a new cdrw goto www.nero.com for the updated version[/url]
Just a simple check before you dig in deeper...
Make sure you have the new svcd compilation window highlighted (by default, the left pane in the file browser.) If you have the right pane highlighted, both the write cd button on the toolbar and the write cd option in the file menu will be unavailable.
Sounds like a no brainer, but I almost had an aneurism one day before I realized the problem.
Regards,
Guardian -
Originally Posted by bidwell88
and the write cd option wont be greyed out
hope this works for you, it worked for me
cheers
TT -
Originally Posted by doug1937@hotmail.com
then choose vcd.
you WILL see an mpegav directory...it'll be just above the area where you drag and drop your files.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
