I am trying to make a menu. But by default, the menu is missing something. So attempting to create one will crash the application when selecting or skipping the audio.
According to this link:
http://download.videohelp.com/liquid217/dvdauthorgui.pl?p=download
I am suppose to download either one to fix the problem. First, I installed the Dscaler MPEG Filters, but it still crashes when attempting to make a menu. Then I tried the GPL MPEG2 Decoder. I do not know what to do with it as there is a bunch of files and no installer nor instructions.
Please help.
Just a guess, you downloaded the .zip? That looks like the source files. Try the .msi - that should be the installer.
A runtime error 339 indicates a problem with the VB runtime components. Try reinstalling, and selecting "full install'.
If that doesn't take care of your menu issue, try using the alternate decoder, found under tools. This requires avisynth, and is much more stable, and typically more accurate than using the directshow decoders. -
DVDAuthorGUI relys on windows media player to display the menu, when using the menu editor. If you are using an older version of windows (like 95/98 ), then you must install Windows Media Player 9.
dvdauthorgui menu question/problem
By tacitus in forum Authoring (DVD)Replies: 7Last Post: 11th Oct 2011, 21:53 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 07:04 -
DVDAuthorGUI, menu button problem
By Pii in forum Authoring (DVD)Replies: 3Last Post: 5th Nov 2008, 05:14 -
DVDauthorGUI problem with large menu
By AlecWest in forum Authoring (DVD)Replies: 3Last Post: 8th Nov 2007, 15:57
