I like to discuss stuff before wasting time...
wmp definitely dislikes my ogg theora I've created with mediacoder even though I've the windows for ogg codecs installed. Even VLC couldn't play it.
However, I was able to simply convert a dv-avi to ogg with ffmpg2theora and VLC liked that.
What I'd like to do now is, since the only thing working on my box I can clearly see is ffmpg2theora, have some control over it with more parameters.
Being a command line tool, I need to resize, kbps, etc...or I'll be stuck resizing and goofing with the avi before it's converted
Any thoughts on this obscure format out there?
Results 1 to 12 of 12
I think I'm looking for this...
options:Code:ffmpeg2theora.exe -o theora_test.ogg --croptop 82 --cropbottom 78 --cropleft 2 --cropright 2 -x 640 -y 256 -v 6 "c:\path to\vts_02_5.vob"main
--output,-o: alternative output
--format,-f: specify input format
--width,-x: scale to given size
--height,-y: scale to given size
--crop[top|bottom|left|right]: crop input before resizing
--deinterlace,-d [off|on]: en/disable deinterlace (enabled by default right now)
--videoquality,-v [0 to 10]: encoding quality for video (variable bitrate/1pass - quality based/in my test -v 6 resulted in ~750kbps)
--audioquality,-a [-1 to 10]: encoding quality for audio
--samplerate,-H: set output samplerate in Hz
--nosound: disable the sound from input
--debug: output some more information during encoding
executed as a .bat
it's probably in the help file
anyone use vdub for this?
any tips?
Thx -
probably.Originally Posted by zoobie
yeah a bat. why not.
but, Super has ffmpeg2theora..
might be useful. (limited i guess)
you can't.Originally Posted by zoobie
mediacoder probably not working due to a bug with vorbis with latest lavf, my guess.
so no point in suggesting avidemux.
no it's ogg.Originally Posted by Ai Haibara
ogm is actually a Tobias hack.
gl"I'll give you five dollars if you let me throw a rock at you" -
I'm using ffmpeg2theora in XP and getting .ogv
yet another container?
I read an older version of mediacoder may be better...
Super "native" support -
Ugh. Well, only because the distinction makes it a little easier for me. I can set aside different players for the .ogm and .ogg extensions. Otherwise, it's a little like .mp4 or .asf, especially when I have Winamp or Media Player wanting to seize control of those extensions.Originally Posted by 45tripp
I've always just seen .ogm videos, though. Never one with the .ogg extension (but note that I'm not saying that means they're not out there.)If cameras add ten pounds, why would people want to eat them? -
This helped put it in perspective
http://en.wikipedia.org/wiki/Ogg_theora
with this on the same page...
...and little support for windowsPrevious evaluations have found VP3 and Theora substantially lacking compared to contemporary video codecs.
next up for me...VLC -
you really like to play those, eh?
ever make one? -
Well, I wouldn't say that.Originally Posted by zoobie
I rarely encounter them, though.
Once or twice, using VDubMod. I guess you can say I've taken them apart more than I've put one together.Originally Posted by zoobie
WebM and OGG Theora in FFMPEGX?
By simpleknight in forum ffmpegX general discussionReplies: 0Last Post: 25th Jan 2012, 13:36 -
Theora best for selling streaming video online?
By sdsumike619 in forum Video Streaming DownloadingReplies: 3Last Post: 12th Jun 2011, 17:07 -
MKV with Video Codec called Theora
By Simmons in forum Video ConversionReplies: 1Last Post: 30th May 2011, 02:17 -
Encode to Theora with VFW/ffdshow
By TheParadox2 in forum Newbie / General discussionsReplies: 16Last Post: 15th Jul 2009, 03:10 -
OGG Files With Theora Video
By DeathStalker77 in forum Video ConversionReplies: 14Last Post: 27th Dec 2008, 18:32
