Hi all!
recently i downloaded 3 avi clips with AC3 5.1 channel audio. I would like to convert and join them to one continuous DVD format with AC3 5.1 channel audio.
Can anyone give me a suggestion on what software to use so that i can watch it in my DVD player with AC3 5.1 audio?
thx!
If they are the same specifications and codec, you can join them with virtualdub (use direct stream copy for both video & audio)
Then you can take the 1 big .avi and use either FAVC or DVD Flick to author your DVD. Select the option to retain 5.1 audio
If you just plug them in separately to FAVC or DVD Flick, they will be 3 separate titles
If they are different specs, it's a bit more complicated. One way might be to encode to DVD compliant MPEG2 (e.g. use HCenc), join them (with something like mpg2cut2), then author DVD separately (e.g. you can use guifordvdauthor or dvdauthorgui, there are a few others)
dvd to mkv/avi with multi audio channel
By vampelle in forum DVD RippingReplies: 1Last Post: 28th Sep 2010, 14:02 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Best way to convert DVD-r w/ 1 channel audio to mono?
By progrocktv in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2009, 16:57 -
DVD > AVI w/o 2 audio channel
By EliteMarine in forum DVD RippingReplies: 4Last Post: 14th Jun 2008, 03:36 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47
