Hey guys!
Seem to be having a slight problem with my wireless on my laptop, Just bought a new Acer Aspire 5920G with Vista Home Premium and when it is connected to my Netgear wireless network it keeps automatically disconnecting then reconnecting every 2-3 minutes but when connected to other networks i don't seem to have the problem, also if i try and do a connection test using my PS3 it keeps timing out, but the wierd thing is my girlfriend doesnt seem to have a problem connecting to the same network and she is also running on Vista but with a shitty Hi-Grade laptop.
Any suggestions?
Results 1 to 15 of 15
I think i am running Service Pack 1 and all my drivers are up-to-date according to windows. By IP6 you mean Internet Protocol 6?
I do have SP1 and i,ve disabled IP6 and the connection seems to be holding! Will post back if i get the problem again!
Spoke too soon!
You mentioned about the Event log, where should i look to find out about the WLAN? -
Ok here what i found.
These information entries seem to appear when ever it disconnects or reconnects
DCHP-Client: Your computer was successfully assigned an address from the network, and it can now connect to other computers.
TCPiP: The system detected that network adapter Wireless Network Connection was connected to the network, and has initiated normal operation.
However i did find this warning entry but it was recorded at 1331 (time is now 1355): Your computer was not able to renew its address from the network (from the DHCP Server) for the Network Card with network address 0013E8F7ABB7. The following error occurred:
The operation was canceled by the user.. Your computer will continue to try and obtain an address on its own from the network address (DHCP) server. -
It sounds like something may have gone bad in the network connection. Try reinstalling network connection to see if that helps.
So clear the setting i already have for this network then start as if it were a new connection?
I've tried re-setting up the Netgear wireless but it is still doing the same!
Would it be worth changing either the Channel or the Mode of the modem?
Did you by any chance install any software that came with the router? Or software from your ISP? If so, you may have 2 or more programs trying to control the Wireless connection and interfering with each other.
Something to try: Open your Wireless Network Connection Properties and on the Wireless Networks tab find the checkbox for "Use Windows to configure my wireless settings". If it is unchecked, try checking it and apply, then reboot your computer, then go back and look at it again, if it is unchecked again then you have a third party software taking control away from Windows.
I recently worked on a laptop for a friend who was visiting from Northern Ireland. He was having similar problems and there was software installed (BT something) that was supposed to control the wireless connection. It wouldn't allow M$ to be the permanent controller, and it didn't play well with the utilities that came pre-installed on the laptop."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Ah you could be onto something there because the laptop came installed with Acer eNet Management which controls the wireless but also windows is trying to do the same, so if i disable the eNet and reset the system it should solve the problem!?
Possibly. Certainly worth trying, don't you think?
Buy My Books
Need 12 cell battery for Acer Aspire One ZG5
By V Bot in forum ComputerReplies: 4Last Post: 18th Feb 2011, 16:14 -
Acer Aspire Wlan
By didikai in forum Video ConversionReplies: 2Last Post: 19th Nov 2010, 18:44 -
Acer Aspire ???
By HotDamn! in forum ComputerReplies: 11Last Post: 19th Apr 2010, 12:07 -
Acer Aspire 5920G blank screen
By nevar in forum ComputerReplies: 0Last Post: 14th Sep 2009, 13:53 -
WIFI Problems on ACER ASPIRE 5920G
By Damned4eternity in forum ComputerReplies: 5Last Post: 18th Aug 2009, 12:21
