can someone tell me what resolution to use if a movie is in proper screener... i'm making this .asf movie into vcd and i would like the pictures to fit the whole tv when watching it instead of having black top and bottom.. thanks
Hi--
VCD's have two standard resolutions--which one to use depends on where you live, since the TV standards differ in America and Europe. If you have a North American TV, you need to use the NTSC resolution of 352x240. If you live elsewhere, try the PAL resolution of 352x288.
As far as getting your movie to fit on the entire screen, go into the settings in tmpgenc and choose "Full Screen (Keep Aspect Ratio 2)". If your source is widescreen, this will cut of some of the sides. If you don't like this, you'll have to live with the letterbox effect. Hope this helped!
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 08:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 09:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
