Dear all,
I have a problem when trying to convert a DV AVI file (around 1 hr long) into WMV format with Two-pass option on. After it finish the 1st pass process it will stop working and prompt a completed box. But the result WMV file only has 6KB large and plays nothing. Look at the log it said the "Output file stopped" after 1st pass and does not goes into 2nd pass encoding process.
I have tried to encode a MPG file into WMV with Two-pass option, it works perfectly.
I have also tried to encode that DV AVI file into WMV with One-pass, it works perfectly too.
I have tried to encode this DV AVI file into WMV with Two-pass in another PC, which works fine as well.
Is there any people having same problem and solved before? Or any suggestion/hints to sort out the problem?
Thanks so much~
Got the same problem ...
... reinstalling the WM Encoder (same version) solved this problem.
rtd1978
Windows Media Encoder - 2 Pass Encoding Problem
By Xenon77 in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2009, 16:51 -
Windows Media Encoder Fails on 2nd pass
By golfer53 in forum DVD RippingReplies: 2Last Post: 20th Feb 2009, 10:36 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 08:19 -
How to convert DV to WMV using Windows Media Encoder
By Baldrick in forum User guidesReplies: 10Last Post: 5th Jan 2008, 01:35 -
Cant convert DV into WMV using Windows Media Encoder
By Viola123 in forum EditingReplies: 2Last Post: 2nd Dec 2007, 14:57
