Dear All,
My PC Config is-
AMD Athlon Dual Core 4000+
ASUS M2A-VM Mainboard
2GB DDR2 RAM 633MHZ
500GB SATA2 HDD Seagate
Liteon DVD RW
I am using TMPGENC Xpress V.4.4.1.237 for ripping of DVDs to MPEG VCD PAL format with default ripping settings.
When I author the ripped MPEG file for DVD with "TMPGEnc DVD Author ver.3.1.2.176" with default authoring settings & play the DVD on DVD Players then the Video Flickers on some DVD players .
But if I Author the same ripped MPEG file with NERO VISION Ver.5 (comes with Nero8 Ultra) then the problem doesn't occurs. The NERO VISION Ver.5 takes long time to author (about 3 Hrs.) compared to TMPGEnc DVD Author (1Hr).
I can't understand that what is the reason of this problem. Is there any settings for TMPGENC Xpress or TMPGEnc DVD Author.
Please Help Me.
Thanks in advance.
Closed Thread
Please don't cross post. One topis is enough. https://forum.videohelp.com/topic355468.html
TMPGEnc DVD Author vs Xpress
By likwid8 in forum Authoring (DVD)Replies: 6Last Post: 20th Oct 2010, 11:56 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
