Hello
I have a strange problem.
I tried exporting my video+audio in all interleave modes and still I get a final product that has glitches in audio.
Tried other video editors like VirtualDUB, AviMUX, Pinnacle Studio 12... same resuts as in adobe export.
Tried mp3 and wave audio in project.
I wanna know if this can be a result of a not very good audio card? I'm using the embeded motherboard chip. The motherboard is GA-P35-DS3 v2.
Thnx for the info
It's possible that audio playback problems might be caused by faulty onboard audio. To test it out, put a sample clip on a USB key and try playing it on another PC (friend's or workplace)
Also you can try other files that have the same audio (e.g. if it was MP3 audio, try playing an .mp3 audio file in winamp or MPC) - does it sound the same? -
audio playback was never a problem
but this the exported avi has big problems playing it for some reason I don't comprehend.
I'll try some things In the mean time more solutions are welcome -
Originally Posted by mkrmecaudio playback was never a problem
What's the problem then? Perhaps you can re-iterate your dilemma more precisely? Is it the video then?
mp3 audio playing/editing is not a problem
it's after I export the damn video the audio gets glithcy..
Steps to edit video in Adobe Premiere Pro CS3?
By LateFate in forum Newbie / General discussionsReplies: 0Last Post: 22nd Apr 2011, 09:21 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Adobe Premiere Pro CS3 ERROR =/
By ervand in forum EditingReplies: 8Last Post: 11th Nov 2008, 23:28
