Hi, I made a couple of projects in tmpg express and outputted to pal 25fps since my source was pal.
I burnt to dvd using tmpg dvd author 3 and I just realized my dvd's were not in pal format but in ntsc, I ripped the .vob from the dvd and loaded in virtualdub went to framerate and it says 29.970, damn that's a dissapointment.
How do i get tmpg dvd author to burn my dvd's in the correct fps I loaded in? I thought it would auto detect and burn it correctly.
What is a better dvd authoring program, easy to use too?
So was your source PAL, or wasn't it?
Did you pick PAL DVD as output format? TDA3 will re-encode if needed. If you feed it a PAL video and have the destination set as NTSC it will encode to NTSC. If you feed it PAL DVD ready video and chose PAL DVD output it will output a PAL DVD.
Your first choice after starting TDA3 is where you most likely made the mistake. -
Thank you! I swear I never noticed that, I thought it was an image not an option.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
GUI DVD Author Project default setting
By Genevieve in forum Authoring (DVD)Replies: 4Last Post: 29th Apr 2009, 02:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
