Hello all, this is my first post here!
I've read loads of places that AVCHD is not supported by Premiere elements (or premiere pro), but in the Elements Data sheet here
https://store2.adobe.com/cfusion/store/flex/index.cfm?store=OLS-UK&storeclient=flex&di...&view=ols_prod
It says supported import/export formats includes H.264. I dont get it ... ???
But if not Adobe for editing, then I'm inclining towards Ulead 11.5 - anyone have anything good to say about it?
I just got a copy of Premiere Elements 4 and will be testing it this weekend.
Premiere Elements or Video Studio will decode h.264 to RGB for processing, then export to your desired format from RGB. The problem is h.264 has significant loss when recoded.
Other editors will cut on I frames (~half second precision) without loss. Some will cut to a frame within the GOP an only recode that GOP.
If you intend to filter or add effects, you can't avoid recode of the entire timeline in Elements or Video Studio.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks edDV, very helpful! (also the link to kiva - something i could def sign up to)
are you shooting/editing avchd then? is there any way to edit it without further degradation? -
I'm using DV and HDV mostly but have AVCHD and other h.264 clips that I use for evaluation.Originally Posted by angstrom
You can cut without loss but not much more. H.264 is designed as a one time distribution format, not a source format.Recommends: Kiva.org - Loans that change lives.
Premiere Elements 9 to AVCHD to DVD disc: How To
By Samsamson in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 15:20 -
Adobe Premiere Elements and AVCHD slow performance
By j0nx in forum Newbie / General discussionsReplies: 8Last Post: 12th Feb 2010, 12:17 -
Will Adobe Premier Elements recognise AVCHD Lite mode
By NP11073 in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2009, 14:05 -
Premiere Elements 7 coming soon -- will have AVCHD capability
By jg0001 in forum Authoring (Blu-ray)Replies: 4Last Post: 10th Oct 2008, 12:20 -
Premiere Elements 4 HELP!
By tczerwinski in forum EditingReplies: 3Last Post: 28th May 2008, 09:55
