I'm trying to edit my clips in the program, however, the clips that are converted to 3ivX is just shown as black when I try to view them in APP. I know this codec has worked for me before, but I can't remember which codec/settings I should install/do to make the clips viewable within the program.
I can convert them to other codecs, but those I've tried made the clips up to 100mb large for a clip that's 5sec long! I don't have that much memory to play with I'm afraid.
help!
/Ces
(I'm using APP 7)
3ivX video clips are absolutely NOT compatible with Premiere, nor is the format easily editable, since it is so highly compressed. Consult your Premiere users manual for compatible video file types.
that's funny, since I've been able to edit with it before, without any problems ...
but I don't have any manual, anyone care to enlighten which codecs I should go for then? -
The manual for CS3 is included on one of the supplement discs that comes with any legitimate purchase of Premiere. Further documentation is also available at adobe.com, and there is a decent Premiere forum at WrigleyVideo.com
don't have the discs either..
(and the school have installed adobe premiere on our laptops, so I *do* have a legimate copy, if that's what you are after.)
but thanks for the help...
Adobe Premiere Pro CS5.5 editting help. It won't let me add any more clips?
By Devilsadvocate in forum EditingReplies: 2Last Post: 28th Feb 2012, 09:55 -
Adobe Premiere Pro CS5.5 Program monitor problem
By jj3502 in forum EditingReplies: 4Last Post: 30th Sep 2011, 11:39 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 15:16 -
Adobe Premiere Pro 2 Problem
By mymuckaccount in forum Video ConversionReplies: 2Last Post: 20th May 2008, 16:17 -
Combine multiple DVD clips in Adobe Premiere Pro
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 12:55
