    Aug 2008
    Ok I did the progress.app thing and my video that i wanted to convert converted in less than a split second,
    so I clicked the blue "i" and got this Error message about what's wrong:
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Tue Aug 19 12:31:49 BST 2008
    [NULL @ 0x54340c]Unsupported video codec
    Input #0, rm, from '/Users/entisarabdalla/Movies/Movie - 013 - Wrath Of The Dragon.rmvb':
    Duration: 00:51:55.3, start: 0.000000, bitrate: 256 kb/s
    Stream #0.0: Audio: cook, 44100 Hz, stereo, 32 kb/s
    Stream #0.1, 12.00 fps(r): Video: RV40 / 0x30345652, 400x300, 217 kb/s
    Stream #0.2: Data: 0x0000
    Incorrect frame rate
    What does that mean Im new.
    2GHz Intel Core 2 Duo 1GB 667MHz Mac book
    Aug 2008
    Ok i fixed the "Incorrect Frame Rate" and now i got this error message:
    Tue Aug 19 12:49:51 BST 2008
    Codec type mismatch for mapping #0.0 -> #0.0
    What's the problem now?
    Aug 2008
    I tried another video codec and it's not working!,
    Error message
    /bin/sh: line 1: /Library/Application Support/ffmpegX/mencoder: cannot execute binary file
    Tue Aug 19 12:52:13 BST 2008
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    ffmpegX doesn't support RMVB files when using the ffmpeg engine. If I told you how to avoid the "Incorrect frame rate", you would still end up with a new error of "unsupported codec".
    On your second try, you're still using settings that use the ffmpeg engine. If I told you how to avoid the "mismatch for mapping" error, you would still end up with a new error of "unsupported codec".
    Actually this is some improvement! This time you used a setting that used the mencoder engine to encode, which is what you should use for RMVB source files.
    1/ Did you install the binaries (mpeg2enc, mplayer, mencoder)?
    2/ Did you install the reallib library for RealMedia support in ffmpegX? There is a reallib for PowerPC and one for Intel processors. Use the one for your chipset.
    3/ reallib is a plug-in for mplayer. Thus, only settings that make use of mplayer can use reallib. This includes all mencoder presets.
    4/ mplayer/reallib has been known to be fuzzy about the source file suffix. Renaming .rmvb to .rm seems to improve support.
    Aug 2008
    Ok thanks I get it now.
    I did the download for Intel cause i got that one
    When i get any further questions ill be sure to ask ya.
