    Aug 2008
    I have a Toshiba DR410 DVD recorder. When I record using dvd+rw, and reauthor using dvdshrink, it shows me only the last session that I recorded and it always shows that twice (which is ok I dont care) but not the previous recordings. For example, if I record programA, stop and then record programB, in dvdshrink I see
    Title 2 - Program B
    Title 4 - Program B
    If I say "full disc" in DVDShrink, it says Invalid navigation structure.
    When I play the disc, titles 1 & 3 seem to be programA.
    What could be a solution for this?
    Thanks.
    Maybe try run fixvts on the video_Ts folder(copy the dvd to your hdd) first and then use dvd shrink.
