So I converted my videos to dvd with menu and I want to reedit the text of the menu, can I open the IFO file and edit the text? Does it work like that? Or do I have to convert the whole thing again? I want to edit the text I mistyped.
If the text is just a highlight then you may be able to fix it with something like MenuEdit or PGCEdit. If the text is embedded in an image or motion menu then you will have to re-create the menu, then slot it back into the disc in place of the one you have. Again, PGCEdit is something to look at. Go to PGCEdit in the tools section, and look at the associated guides, then go from there.
Read my blog here.
https://forum.videohelp.com/topic313743.html#1606732
If it's a static menu and all you want is to edit some text, then scroll to the bottom to The Easy Way.
S-video to standard TV connection -- can text be made readable?
By gumbygum in forum Software PlayingReplies: 5Last Post: 28th Feb 2009, 05:27 -
Blurred Text on DVD Menu
By boofer in forum Authoring (DVD)Replies: 3Last Post: 10th Jan 2009, 18:45 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 12:25 -
ADVICE SOUGHT - RE-Editing DVD made from VHS
By Hal05154 in forum Authoring (DVD)Replies: 3Last Post: 22nd Mar 2008, 13:25 -
DVD Lab - menu text blurred (PAL)
By BeachNut in forum Authoring (DVD)Replies: 12Last Post: 21st Jan 2008, 07:12
