Wondering what files do I download so I can play them in my Sony DVP-NS63P player?
				Results 1 to 11 of 11
	edit
	Try to frame your question clearly with details. No one here is psychic...
	I'm guessing....
 AutoGK to convert DVDs to Divx for playback from a CD.
 ConvertXToDVD if you want DVD MPEG format for playback on a DVD. Or freeware, FAVC.
 Or if you are using files off the net, just burn them to disc if they are Divx compliant. This data from jman98 is what doesn't work with most Divx set top players:
 Also, VBR audio might cause problems with some players, as well. If your AVIs have any of the above, you might need to modify/recompress them before they'll play on your player.Originally Posted by jman98
	I already download torrents for music, I now want to do the same for movies. My Sony dvd player only recognizes dvd's that are from the North American region, I found this out awhile back because my better half downloaded some movies, some would others wouldn't. I did some talking at work, a fellw told me to try to find full dvd torrents that contain NTSC files. Just for curiosity sake I'm downloading a movie in avi. format, will this play in my SonyDVP-NS63P player? I just simply want to download a full dvd torrent burn it to disc and watch it, without having to buy or download software to convert files
	I don't know that much about that Sony player, but I would give it a try with PAL Divx AVIs. If it doesn't work and the video is Divx compliant, use a program like ConvertX or FAVC to 'translate' it to a NTSC DVD. Then it should work.
 BTW, if you are asking about copyrighted movies off the net, then that is a violation of our rules. Please read our rules before posting. Please read our rules before posting.
	Here. RTFM: http://esupport.sony.com/LA/perl/model-home.pl?mdl=DVPNS63P&LOC=3. Sony says it's only available in Latin America, NOT Canada.
  Download all files from a mms serverBy shorto in forum Video Streaming DownloadingReplies: 2Last Post: 7th Sep 2011, 03:07
  Which Download Files to UseBy redneckbcer in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2009, 11:55
  Uploading files for Direct DownloadBy xeroid in forum Newbie / General discussionsReplies: 4Last Post: 8th Nov 2008, 20:53
  Can't download filesBy sbuckmybballs in forum ComputerReplies: 7Last Post: 24th Dec 2007, 11:38
  Where can I download firmware files for Toshiba SD-V392?By guru1 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Nov 2007, 17:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
