I'm looking for a standalone USB 2.0 Divx/Xvid player to connect to my TV.
It must have an infrared remote control, scart output (RGB), and usb (2.0) input.
Are there any?
The only one I found was Tvisto pro.
I also thought of buying a pioneer dv-400 dvd with usb input instead.
Any recommendations?
Don't have Philips here at all.
Btw, DVD playback isn't necessary at all.
Just to copy from the PC and playing it on the media player (RGB to tv).
I understand that a DVD player with USB is probably the best solution in this case (considering low price)? -
Just be on notice that I believe most dvd players don't handle high def resolutions for file playback. Meaning you'd be stuck at 720x480 or pal 720x576 (check me if I'm wrong on that pal figure).
If you don't need dvd playback check out hard drive enclosures with media playback ability. Some can do high def video files.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
720x480/720x576 - That's the maximum resolution I currently need (regular sony tv).
Which non-dvd players support higher resolutions?
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Using 500GB usb drive as player on Standalone with USB
By OdubruS in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jul 2007, 06:36 -
Standalone Divx/Xvid player Q
By g0dm0de in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2007, 00:14 -
Budget DVD player with DivX, upcovnerting & USB
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th May 2007, 12:24
