I know Windoze has come a long way since the 90's (in some regards anyway) and most "modern" applications are keeping up...
Are there any inherent dangers or pitfalls to installing programs to a different secondary hard drive instead of the default C:\Program Files folder?
I've been racking my mind trying to think of any problems this could cause, but not coming up with anything.
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Updates can become a hassle for programs not installed to their default.
Windows doesn't care though -
I install most of my apps in top level folders on a separate drive.Originally Posted by Xylob the Destroyer
However a few stubborn apps insist on creating folders in "Program Files".
For one thing I use batch commands quite a lot so I like shorter paths, and I hate spaces and punctuation in folder names. They can cause mysterious glitches. For the same reason I always use "Custom" install and drastically shorten the default folder and file names. Eg, instead of:
c:\Program Files\Bartholmew's Super Software Company\Bartholomew suite\Version 6.3.2 alpha\My wonderful app!!!"
I make something like P:\Bart\ -
Thanks guys.
I occasionally run into a program that doesn't like running on mapped network shares. (I have a share mapped as drive G: on all my computers.)
yeah, I'd tried installing stuff to mapped network drives in the past - it just didn't work out.
What I'm currently considering is installing to a second hard drive that is physically in the same PC.
I've done it with some emulators, but those aren't (all) really installed and more like stand-alone programs (with the exception of my PS2 emu)."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Audio software that "overrides" default file-types/icons
By djdust in forum Software PlayingReplies: 0Last Post: 15th Apr 2011, 04:09 -
Easy way to default existing subtitle to "on" when backing up?
By Spoffo in forum SubtitleReplies: 1Last Post: 30th Jan 2011, 22:50 -
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 06:30 -
Is it possible to change the default "Open" view?
By SLK001 in forum ComputerReplies: 5Last Post: 22nd Oct 2008, 12:38
