  1. Member MI6's Avatar
    Aug 2004
    MACEDONIA
    My friend send me 9 DVD Discs filmed with his DV camera that records directly to DVD discs, but 6 of them he forgot to finalize with his camera.Is any chance to finalize discs by my self without original camera?
    QUALITY HAS A NAME
    Apr 2004
    Miskatonic U
    If you canb find one of the same model you might be able to finalise them
    Read my blog here.
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You may be able to read and copy files from them with Isobuster without finalising.
    Aug 2003
    Denmark
    You mention DVD disc's, so here is how to finalize these:
    Get a copy of ImgBurn -
    Insert the problem DVD in your PC-drive and launch ImgBurn.
    Then use menu "Tools / Drive / Close / Track" - it will take a minute or so
    Then use menu "Tools / Drive / Close / Session" - it will take a minute or so
    Then use menu "Tools / Drive / Close / Drive" - it will take a few seconds
    Your problem DVD should now be finalized and you should be able to use it as a normal DVD.
    regards Politiken
    Jun 2012
    Hungary
    I got ImgBurn, but Drive cannot be open in Tools.
    When I choose "Verify Disc" or "Discovery" I can open Tools - Drive - Close - Track
    However, after letting work Track a few minutes
    at Session - I get the message that "I/O error! bla, bla, bla, Medium Not Present - Tray Closed.
    Further more, the third is cold "Disc" - not "Drive"
    (I have lived in the UK and I did not finalize about 50 DVDs
    Thank you, Brgds
    Gyula
  6. The pro version of IsoBuster is the only sure way to extract the video if you can't get the camcorder to finalize, just for fun you might try DVDDecrypter as some people have reported success finalizing a DVD.
    Jun 2012
    Hungary
    Thank you
    However, the recorder is a Sony DVD Recorder RDR -HXD710, but I cannot afford to back to the UK.
    The same time I realy need to finalize them. I did not have any experience with such things before, so ....
