which tool to use? i am trying to convert some DIVX files to avi for conversion to DVD using tmpgenc and tmpgenc author. well versed in both of these tools, but not so much in using divx files.
thanks in advance!![]()
Results 1 to 10 of 10
.DIVX files? It may be enough just to rename to .avi.
ok, i renamed them .avi files but it still says under properties that it is a divx file. how do i actually change the file type?
Think of AVI as an envelope in which you place your audio and video files. Those video files might be Divx, Xvid, h264, etc. So comparing AVI to Divx is like comparing an envelope to the items you place inside it.
As long as you have the codec to play back DivX files (such as ffdshow ), tmpgenc should accept the file for conversion. -
ok, got it, i had to change my view to show the file extensions, thanks again for all your help!
ok, new problem, same files. i got the divx files to be avi files by changing the extention and they are recognized as such by virtualdub. tmpgenc is not recognizing them though. what gives?
originally i did not see the file extensions, but i fixed that problem
TMPGEnc DivX conversion BLOCKED-LIKE avi
By visitor in forum Video ConversionReplies: 2Last Post: 26th Dec 2009, 10:32 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 18:15 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Xvid/DivX avi to smv conversion
By marcopolo1 in forum Video ConversionReplies: 3Last Post: 17th May 2008, 07:49 -
Conversion to Divx AVI for RCA DRC8052
By Shilar in forum Video ConversionReplies: 2Last Post: 9th Dec 2007, 12:15
