I know it's always a trade off between quality and streaming speed but is there a "rule of thumb" file size not to go beyond for an flv file?
Been playing around with the settings in Sorenson Squeeze 5 for the last few days. Found a quality I'm happy with - the resulting file size is about 50MB. The videos are 7-10 minutes long with the following settings:
- 448 x 336
- 768kbps data rate
- 20 fps (original shot in 25 fps)
- 80kbps / 22050Hz audio
Thanks for any input you can give.
1) It depends on your audience. If they are in London, UK they probably have access to broadband. If they are in rural India, chances are they might only have dialup, in that case you would want to go with a smaller less extravagant flash video
2) Bandwith costs money. If you are super rich and don't care, or if this is for a big corporation (like Apple movie trailers), or a "free" hosting site, then by all means, go all out.
3) Honestly, hardly anyone uses .flv for "quality" streaming anymore. You can use h.264 video / aac audio / .mp4 container for streaming flash with Adobe Flash 9 update 3. You will get better quality (audio & video) AND smaller size by choosing this over Sorensen. The downside is it takes more CPU power to encode and decode. Have a look here for comparisons, links to examples & more info
https://forum.videohelp.com/topic355118.html
Baldrick also put up a tutorial
https://www.videohelp.com/guides/how-to-convert-any-video-to-high-quality-flash-mp4-wit...te-id1082#1082
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 17:21 -
Does Streamtransport have a practical simultaneous download limit?
By yoda313 in forum Video Streaming DownloadingReplies: 5Last Post: 31st Jul 2010, 18:56 -
Question about avi file size limit for DVD players
By jimdagys in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Dec 2009, 03:12 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
VDub/MOD cant limit my file size?!?!
By GangstaRap in forum Video ConversionReplies: 6Last Post: 29th May 2007, 04:36
