When I choose to burn a dvd in Encore, Encore starts with importing Sequence 1 (I only have one).
'Data written' and 'Time remaining' are both zero.
Everytime the processing reaches the end of the bar, it just goes a little bit back and then it goes to the end again.
It's kinda hard to explain, so I've added a picture:
Does anyone know how I can slove this problem? Because it stops me from burning a dvd!
(BTW, there where no errors before burning the dvd!)
Results 1 to 12 of 12
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
We have an "Authoring DVD" forum and you're not a newbie. Why on earth did you post this here? This has nothing to do with VCD/SVCD.
Moving you.
Looks like it can't convert the avi video source.
Does it happen with all video sources? -
Yes, is does. Is there anything that can solve the problem?
I've tried several video's, but what they have in common is that they are all converted. I did that, because otherwise Encore wouldn't load them because of the videoframe(?) size, and the frame rate.Kate: What's the big thing that happens every Monday at one o'clock?
Export from Premiere Sequence 1 to mpeg2 dvd files (m2v and wav files)
and import to Encore this files -
I'll try that, but I do need to encode the file first because it's an MKV.
I've imported an AVI file, but I can't export it to Encore. When I try to render the 25 minute long video, Encore needs 3(!) hours to render the file!
When I import the AVI in Encore, Encore needs to transcode the videofile. When it's almost finished, Encore starts to do the same thing as when I try to burn a dvd!Kate: What's the big thing that happens every Monday at one o'clock?
With the AVI in premier, chose File>Export>Adobe Media Encoder and using the following settings:
Format: MPEG2-DVD
Range: Entire Sequence
Preset: PAL/NTSC normal screen or widescreen, up to you, but chose "High Quality"
Click O.K to export the mpeg2 file. Remember where you save it, then import this video into Encore. -
I can''t choose MPEG2-DVD, only Adobe Flash Video, Quicktime, RealMedia and Windows Media. All of them have major quality loss :S
Strangely enough, I can export to Encore right now. Problem is that Premiere CS3 shuts down because it can't handle the request to export to Encore. Could it be because I have Encore CS2?Kate: What's the big thing that happens every Monday at one o'clock?
Premier does have a builtin MPEG2 encoder (Mainconcept). If the option is not available for you, then something is seriously wrong with your copy.
I'd suggest a reinstallation.
http://img135.imageshack.us/img135/9577/ppexport3cm4.png -
Thanks, I did a reinstallation and now it works
I'm burning the dvd right now...
Edit:
I've burned the dvd, but a lot of scenes are choppy. One episode doesn't even play!
What's with that?Kate: What's the big thing that happens every Monday at one o'clock?
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 05:46 -
Burning DVD Encore 2.0
By Usagi Tsukino in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2009, 13:10 -
Adobe Encore question...
By sdsumike619 in forum Authoring (DVD)Replies: 18Last Post: 5th Aug 2009, 00:58 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 21:43 -
adobe encore question
By meshnut in forum Authoring (DVD)Replies: 5Last Post: 5th Dec 2007, 15:53
