I have just been looking on the following web site to see if my PC can run certain games. http://www.systemrequirementslab.com/referrer/srtest
In the info I am given after it tests my PC, it says I have the following;
You Have: 2 processors running - Intel(R) Pentium(R) 4 CPU 3.00GHz
You Have: 2.99 GHz Performance Rated at 4.49 GHz
How do I tell if I have 2 processors running, and can I make full use of them if I have two?
You probably have a single Pentium 4 CPU with hyperthreading. Hyperthreading can squeeze a little more performance out of the CPU (~10 percent) compared to a P4 at the same clock speed without hyperthreading. Hyperthreading allows the CPU to run two threads at the same time. But it is nowhere near as efficient as having a two CPUs or a dual core CPU.
The Cpu is mostly not the thing holding you back.. its more likely to be your Gfx card. If you play games, like crysis, then your money is best spent on high horsepower gfx. A Pentium 4 3.0ghz is pretty reasonable for 90% of games available today.. remember a lot of them are designed to run on consoles with their pathetic CPU's and graphics.
*heatshield activated*Corned beef is now made to a higher standard than at any time in history.
You can also check 'Task Manager>Performance'. It shows how may cores or CPUs you have.
Intel Processors
By hardy in forum ComputerReplies: 6Last Post: 9th Jul 2011, 17:21 -
Whether using 2 the processors
By aphanri in forum ComputerReplies: 2Last Post: 7th May 2010, 07:34 -
Does FFmpegX use multiple processors?
By WilliamD in forum ffmpegX general discussionReplies: 3Last Post: 9th May 2009, 12:10 -
Processors....
By rubberman in forum ComputerReplies: 31Last Post: 13th Sep 2007, 10:52 -
Processors
By video_enthusiast07 in forum ComputerReplies: 5Last Post: 15th Jun 2007, 13:59
