http://freeforum.avg.com/read.php?12,142806,backpage=,sv=
UPDATE .BIN error information... Aug 16th 2008
Posted by: rdsok - Moderator (IP Logged)
Date: August 17, 2008 12:07AM
Currently the update for AVG Free v8 is corrupted... you will have to wait for AVG Technologies to address the issue with the update.
Reporting the issue again by other users here will not do any good util it is resolved.
The updates that your AVG currently have will still provide the protection it is setup to detect. In otherwords, not being able to get this update will not make your AVG Free ineffective and as soon as AVG Tech resolves the issue you will be able to update to the current virus definitions at that time.
So in short... please do not post to report the issue, its already known. Also please be patient until AVG Technologies can address the issue.
Also... for those user that did report the issue... thanks for the info.
Edited 2 times. Last edit at 08/17/08 04:23AM by rdsok.
the avg server is/was toast. if you are still having problems getting an update, they are available here-
http://www.softpedia.com/get/Others/Signatures-Updates/AVG-AntiVirus-Definitions.shtml--
Thanks for that info. I was wondering WTH was going on with missing bin file.
I uninstalled AVG8, it was a resource hog on par with Norton and McAfee. I kept 7.5 on two systems. Tested Avast! but was wholly unimpressed. Currently running Avira on the non-AVG7.5 machines.
I turned off the resident shield and link scanner that was suggested by another member. Now it's not a resource hog.
i run norton on 2 machines and avg8 on 2 and never see more than 1% cpu usage from either. i don't get the resource hog references at all. both do the job they are designed to. i prefer the norton systemworks package for the additional features but avg8 free works fine here with everything turned on.
Thread should be locked
They seemed to have fixed their problem.....least that's what I've been told
I don't use AVG
Plus I would hate to see this thread fall into the realm of the not matter in the first place
How to determine if a mkv / avi / whatever file is constant or avg bitrate?
By smackyourfupa in forum Newbie / General discussionsReplies: 3Last Post: 8th Oct 2011, 05:26 -
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 11:26 -
Can no longer scan just one file in AVG
By V Bot in forum ComputerReplies: 7Last Post: 29th Mar 2010, 09:22 -
Audio missing in VOB file
By marknyc5 in forum DVD RippingReplies: 3Last Post: 20th Jul 2008, 19:48 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 16:02
