I've searched all day trying to find help so I finally decided to join up and ask for assistance.
I'm trying to backup Weeds Season 3 Disc 2 and keep running into a problem. For some reason, it won't copy to my HD. There seems to be an issue with VTS.01.01 and VTS .06.01. Neither will go through any software. i've tried DVDshrink (which worked with the other 2 discs in the season) and get a data redundancy error or something (sorry I'm not at my home PC), DVD Fab gets jammed at the same spot. I run CSS region free and the dvd shows as having no encryption in both those programs. The house I'm at now has AnyDVD and Clone DVD and it still gets stuck in the same part. I've tried two different original copies of the DVD and still keep getting stuck.
Any help or direction to a guide that could help is much appreciated.
EDIT: Here is the actual Clone DVD error I receive:
Processing error
E:/VIDEO_TS/VTS_01_1.VOB: read error
The system cannot read from the specified drive.
If reading the media has failed, please clean the surface and try again.
Details:
File 1 E:/VIDEO_TS/VTS_01_1.VOB 30 TCSectorReader
FYI: the disc is as clean as they come. Brand New DVD
So your a Weeds fan ... man ... things have changed on this show ... haven't seen the show for awhile.
I just activated Showtime on Directv a few days ago and we watched the latest episode ... the broad from ... "BIG" the movie with Tom Hanks ... she is all screwed up. -
It says you have a read error. You've got a bad spot on your DVD. It isn't a software issue.
Originally Posted by ybeard
